Normalizing Hermite Polynomials
In summary, the normalization integral in (22.15) is correct except for the extra factor of -1 that should not be there.
rmiller70015
110
Evaluate the normalization integral in (22.15). Hint: Use (22.12) for one of the $H_n(x)$ factors, integrate by parts, and use (22.17a); then use your result repeatedly.
(22.15) ##\int_{-\infty}^{\infty}e^{-x^2}H_n(x)H_m(x)dx = \sqrt{\pi}2^nn!## when ##n=m##
(22.12) ##H_n(x)=(-1)^ne^{x^2}\frac{d^n}{dx^n}e^{-x^2}##
(22.17a) ##H'_n(x)=2nH_{n-1}(x)##
I started out by writing my integral from (22.15) as:
##\int_{-\infty}^{\infty}e^{-x^2}[H_n(x)]^2dx##
Expanding one of the ##H_n(x)## terms gives:
##\int_{-\infty}^{\infty}e^{-x^2}H_n(x)e^{x^2}(-1)^n\frac{d^n}{dx^n}e^{-x^2}dx##
##=(-1)^n\int_{-\infty}^{\infty}H_n(x)\frac{d^n}{dx^n}e^{-x^2}dx##
Integration by parts and using equation 22.17a gives:
##(-1)^n[H_n(x)e^{-x^2}|^{\infty}_{-\infty}-\int^{\infty}_{-\infty}2nH_{n-1}(x)\frac{d^{n-1}}{dx^{n-1}}e^{-x^2}dx##
The first term goes to zero and leaves:
##(-1)^n\int^{\infty}_{-\infty}2nH_{n-1}(x)\frac{d^{n-1}}{dx^{n-1}}e^{-x^2}dx##
IBP n-1 more times gives:
##(-1)^n2^nn!\int^{\infty}_{-\infty}H_0(x)e^{-x^2}dx=(-1)^n2^nn!\int^{\infty}_{-\infty}e^{-x^2}dx = (-1)^n2^nn!\sqrt{\pi}##
This is correct except I have this extra factor of ##(-1)^n## that shouldn't be there, I'm not sure how to get rid of it.
Hi rmiller,
Let's take a closer look at the IBP:
Shouldn't that be:
$$(-1)^n\left[H_n(x)e^{-x^2}|^{\infty}_{-\infty}-\int^{\infty}_{-\infty}2nH_{n-1}(x)\frac{d^{n-1}}{dx^{n-1}}e^{-x^2}dx\right] \\
=(-1)^n \cdot \left[ -\int^{\infty}_{-\infty}2nH_{n-1}(x)\frac{d^{n-1}}{dx^{n-1}}e^{-x^2}dx \right] \\
=(-1)^{n-1} \int^{\infty}_{-\infty}2nH_{n-1}(x)\frac{d^{n-1}}{dx^{n-1}}e^{-x^2}dx
Likes rmiller70015
For future people, you get a factor of -2 each time you do ibp and in the end you're left with (-1)^n (-2)^n when you combine them it gives 2^n.
Related to Normalizing Hermite Polynomials
1. What are Hermite polynomials and why are they important in normalization?
Hermite polynomials are a set of orthogonal polynomials that are commonly used in mathematics and physics. They are important in normalization because they form a complete orthogonal basis for functions in the space of square-integrable functions.
2. How are Hermite polynomials normalized?
Hermite polynomials are normalized by dividing each polynomial by a normalization constant, which is the square root of the product of the factorial of its degree and the constant pi.
3. What is the significance of normalizing Hermite polynomials?
The normalization of Hermite polynomials allows for the creation of a complete orthonormal basis for the space of square-integrable functions, which is important in many areas of mathematics and physics.
4. How are Hermite polynomials used in quantum mechanics?
Hermite polynomials are used in quantum mechanics to solve the Schrödinger equation, which describes the behavior of quantum systems. They are also used in the creation and annihilation operators for quantum harmonic oscillators.
5. Are there any real-world applications of normalized Hermite polynomials?
Normalized Hermite polynomials have many real-world applications, such as in signal analysis, image processing, and data compression. They are also used in the study of quantum mechanics, electromagnetics, and fluid dynamics.
