MHB Not an exercise, more of a question.
  • Thread starter Thread starter IHateFactorial
    Exercise
To determine the unique ways to sum to a number n using u addends, where order matters and all addends are positive integers, a combinatorial approach is necessary. The problem can be framed as finding the number of integer solutions to the equation x1 + x2 + ... + xu = n, with the constraint that each xi > 0. The generating functions or the stars and bars theorem can be applied to simplify the calculations. For the example of n=6 with u=4, the formula involves calculating permutations of the partitions of n into u parts. This method avoids the tediousness of manually listing permutations and ensures all unique combinations are counted.
IHateFactorial
If I have a number n and I want to know all the unique ways in which I can use u addends to get that number... How do I do it?
For example: If the number is 6 and I want to see how many unique ways I can add up to it (order matters: $$1 + 1 + 2 + 2\ne 2 + 2 + 1 + 1$$) by using 4 addends, what's the formula? (This is, in fact, considering that all the addends are greater than 0 and whole numbers.)
I can do it by looking for each unique way to add up to n using u addends and then factoring in the number of ways each can be permutated, including repeated numbers, but that seems too tedious.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
