Not seeing how to integrate y/(y+1)
  • Thread starter opticaltempest
  • Tags
    Integrate
In summary, the conversation discusses how to evaluate the integral \int {\frac{y}{{y + 1}}dy} by expressing it as the sum of two fractions with the same denominator. This can be done by writing y as y+1-1 and then using substitution to simplify the integral. The final result is y - ln|y+1| + C.
opticaltempest
135
Hello,
I cannot figure out how to evaluate the following integral,
[tex]\int {\frac{y}{{y + 1}}dy}[/tex]
If it was [tex]y^2+1[/tex] then I see how a u-substitution of [tex]u=y^2+1[/tex] would work.
Thanks
Usually with fractions like this, you'll find you can express what you have as the sum of two or more fractions with the same denominator which are easier to integrate. In this case, try the numerators y+1 and -1.
As in, write y = y + 1 - 1.
Ok, that is what I was having trouble seeing. Thanks
[tex]
\frac{y}{{y + 1}} = \frac{{y + 1}}{{y + 1}} - \frac{1}{{y + 1}} = 1 - \frac{1}{{y + 1}}
[/tex]
[tex]
\int {1{\rm }dy - } \int {\frac{1}{{y + 1}}{\rm }} dy = y - \ln \left| {y + 1} \right| + C
[/tex]
You could also substitute u = y + 1, du = dy, and get the integral of (u - 1) / u with respect to u.
FAQ: Not seeing how to integrate y/(y+1)
Can you explain the concept of integration?
Integration is a mathematical process of finding the anti-derivative of a function. It involves reversing the process of differentiation and is used to calculate the area under a curve.
What does the notation "y/(y+1)" mean?
The notation "y/(y+1)" represents a rational function, where the numerator is y and the denominator is y+1. It is a type of algebraic expression that involves both variables and constants.
Why can't I see how to integrate y/(y+1)?
Integrating a rational function can be challenging as it involves various techniques such as partial fractions, substitution, or integration by parts. It is possible that you may not be familiar with these techniques, which is why it may be difficult for you to see how to integrate y/(y+1).
What are the steps to integrate y/(y+1)?
The steps to integrate y/(y+1) involve rewriting the rational function using partial fractions, performing substitution, and then using the appropriate integration technique. The specific steps may vary depending on the form of the rational function and the chosen integration technique.
Can you provide an example of integrating y/(y+1)?
Sure, let's say we want to integrate y/(y+1) using the substitution method. We can substitute u = y+1, which means du = dy. The integral then becomes ∫ y/(y+1) dy = ∫ (u-1)/u du. This can be solved using the power rule, resulting in the final answer of u^2/2 - u + C. Substituting back u = y+1, we get the final answer of (y+1)^2/2 - (y+1) + C.
