PhyIsOhSoHard
- 158
Did I solve this correctly? I'm not sure if my method is correct.
A metal cylinder with the specific heat [itex]c_{cylinder}[/itex] and mass [itex]m_{cylinder}[/itex] is warmed up to temperature [itex]T_{cylinder}[/itex] and then cooled down by putting it into water which has the temperature [itex]T_{water}[/itex] and mass [itex]m_{water}[/itex] and specific heat [itex]c_{water}[/itex].
Find an expression for the final temperature [itex]T[/itex] (the equilibrium temperature).
Afterwards consider the following values:
[itex]T_{cylinder}=600 °C[/itex]
[itex]T_{water}=20 °C[/itex]
[itex]m_{cylinder}=2 kg[/itex]
[itex]m_{water}=2 kg[/itex]
[itex]c_{water}=4190\frac{J}{kg\cdot K}[/itex]
[itex]L_{water}=2256\frac{kJ}{kg}[/itex] (heat of vaporization)
Calculate the final temperature if the cylinder was made of copper with specific heat [itex]c_{Cu}=390\frac{J}{kg\cdot K}[/itex] and comment on the result.
Then calculate the final temperature if the cylinder was made of aluminum with specific heat [itex]c_{Al}=910\frac{J}{kg\cdot K}[/itex] and comment on the result.
Heat required for temperature change ΔT of mass m:
[itex]Q=mcΔT[/itex]
Energy conservation relation:
[itex]∑Q=0[/itex]
Heat transfer in a phase change:
[itex]Q=mL[/itex]
Using the first equation listed above for both the cylinder and water:
[itex]Q_{cylinder}=m_{cylinder}c_{cylinder}(T-T_{cylinder})[/itex]
[itex]Q_{water}=m_{water}c_{water}(T-T_{water})[/itex]
The energy conservation relation yields:
[itex]Q_{cylinder}+Q_{water}=0[/itex]
[itex]m_{cylinder}c_{cylinder}(T-T_{cylinder})+m_{water}c_{water}(T-T_{water})=0[/itex]
Isolating the final temperature T gives the expression:
[itex]T=\frac{m_{water}c_{water}T_{water}+m_{cylinder}c_{cylinder}T_{cylinder}}{m_{water}c_{water}+m_{cylinder}c_{cylinder}}[/itex]
If the cylinder was made of copper:
I assume that the water does not boil so the final temperature will be less than 100 °C (boiling point of water).
[itex]T=\frac{2\cdot 4190\cdot 20+2\cdot 390\cdot 600}{2\cdot 4190+2\cdot 390}=46 °C[/itex]
If the cylinder was made of aluminum:
[itex]T=\frac{2\cdot 4190\cdot 20+2\cdot 910\cdot 600}{2\cdot 4190+2\cdot 910}=82 °C[/itex]
[itex]Q=mcΔT[/itex]
[itex]∑Q=0[/itex]
[itex]Q=mL[/itex]
