Not understanding this series representation
In summary: I'll try to summarize it better next time.In summary, the problem asks for a formula for the sum of a series of negative integers, but the identity does not appear to be applicable.
Kyle Nemeth
25
[mentor note: thread moved from non-hw forum to here hence no homework template]
Can someone explain to me how it is that
$$\sum_{n=a}^b (2n+1)=(b+1)^2-a^2$$
I thought it would be $$\sum_{n=a}^b (2n+1)=(2a+1)+(2b+1)$$
but I am clearly very wrong. I would greatly appreciate any help.
It is summing the series from a to b (integers). This basically means you can take the difference of the sum from (n=1 to n= b) and of the sum from (n=1 to n=a-1). Both of those sums you should be able to compute. ## \\ ## Note: I think problems of this kind normally would go to the homework section. Please post in the homework section if it involves a homework exercise. :-) :-)
The 2n+1 should give you a clue especially if a=0 then you get the sum 1+3+5+...
We can't solve this problem for you so please show some work before we post more.
Likes Charles Link
Wow, took me a bit to figure out what everyone was saying! I thought combinatorics prepared me for any summation I might see!
Kyle,
I don't know if you're missing some qualifiers or something from your statement. But it would have been clearer to me if it was written:
$$\sum_{n=a}^b (2n+1)=(b+1)^2-a^2 , \qquad \forall a,b \in \mathbb{Z} a \leq b $$
Think of it as an identity that helps you compute a summation for two integers meeting that criteria, rather than a formula to just write out. To see that it works, plug in a couple of numbers.
It's a nice identity and I've either never seen it, or it's so basic I have forgotten.
-Dave K
Likes jedishrfu
Kyle,
You're definitely a true mathematician now! :-)
Yes, its important to indicate the membership bounds of a and b to make this problem solvable.
Likes dkotschessaa
I apologize for the sloppy post. Thanks everyone for the help and guidance.
Your work? Mathematicians are standing by to answer your questions... :-)
If that's true I should probably go and prove it now...
Was it written with the bounds like that? Just curious, might not have been you.
I learned something anyway.
-Dave K
Likes jedishrfu
I believe, it has to do with the formula of an arithmetic progression, and mathematical induction (how to arrvie at the identity). Combining them or something. But mathematical induction only applies in the set of natural numbers. :sorry: and also I don't see how the identity applies to negative integers, as the squaring removes the negative one one side but not the other. :sorry::sorry:
edit: oh man, I am really missing something here
FAQ: Not understanding this series representation
What is a series representation?
A series representation is a mathematical expression that represents a function or a sequence as an infinite sum of simpler terms. It is often used to approximate more complex functions and make them easier to work with.
How do I know if I have the correct series representation?
To determine if a series representation is correct, you can use a variety of methods, such as the ratio test, the comparison test, or the integral test. These tests can help determine if the series converges or diverges, which is an important factor in determining correctness.
Can a series representation be used to solve any mathematical problem?
No, not all mathematical problems can be solved using series representations. They are most commonly used for functions that can be expressed as a power series, and may not be applicable to other types of functions.
How does a series representation relate to Taylor series?
A Taylor series is a type of series representation that is used to approximate a function as an infinite sum of polynomial terms. It is a special case of a series representation and is often used to calculate derivatives and integrals of a function.
Are there any real-world applications of series representations?
Yes, series representations have many real-world applications, particularly in physics and engineering. They can be used to model and solve problems related to heat transfer, fluid dynamics, and electrical circuits, among others.
