B Notation for a "scalar absolute field"?
The discussion centers on a proposed notation for describing a scalar absolute field derived from a vector field in three-dimensional space. The notation suggests integrating the absolute values of vector components without cancellation, leading to a scalar result that represents the field's magnitude. An example illustrates how to calculate the resultant force from two vectors, emphasizing the importance of summing absolute values before normalizing. The conversation also touches on the application of this method to gravitational and other force fields, advocating for a straightforward approach without the need for new notation. The proposed method effectively simplifies the integration of scalar magnitudes for various forces.
timjdoom
TL;DR Summary
I have a mathematical expression which I'm unsure of the formal representation or name of. The best way I can think to describe it is as a "scalar absolute field".
The notation I think best describes it is
## F = \lVert\int^{space}_s|\vec{V}|ds\rVert ##
So you have a vector field V in a 3d space. For each point you integrate over all of space (similar to a gravitational or electromagnetic field) *but* vectors in opposite directions do not cancel, they add to the magnitude (i.e. you integrate the absolute of the vector). Then finally you want the scalar value, so you normalise the vector.
For context the python (numpy) code to express it is given say a 4-dimensional array `vec` (a 3D vector in 3D space) might be
Python:
xyz = np.array([np.sum(dimension) for dimension in np.abs(vec)])
field = np.sum(xyz**2, axis=0)**0.5
Example for gravitation (or charge) in a 2D space
- You have a mass ##M_a## at position a, exerting a force ##\vec{F_a} = -3\hat{x} +3\hat{y}## on point p.
- Next you have a force ##M_b## at position b, exerting a force ##\vec{F_b} = +2\hat{x} +2\hat{y}## on point p.
- The vector force at point p is therefore ##\vec{F_p} = \vec{F_a}+\vec{F_b} = -1\hat{x} +5\hat{y}##
- Meaning the absolute of the vector is ##|\vec{F_p}| = 1\hat{x} + 5\hat{y}##, and normalising would give you the scalar of ##\lVert\vec{F_p}\rVert = \sqrt{1^2+5^2} = \sqrt{26}##
- What I need is ##|\vec{F_a}|+|\vec{F_b}| = (|-3|+|2|)\hat{x}+ (|3|+|2|)\hat{y} = 5\hat{x}+5\hat{y}##, which gives you the scalar ##\lVert|\vec{F_p}|\rVert = \sqrt{5^2+5^2} = \sqrt{50}##
Mathematics news on Phys.org
Just integrate the scalar rho/r2 for gravity, and whatever other magnitude you have for other forces? No need to invent more notation.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
