Notched specimen under constant K and temperature gradient
In summary: Expert SummarizerIn summary, the conversation discusses the concept of fracture toughness and its relation to crack propagation. It poses a scenario where a specimen with a pre-existing crack is subjected to a constant crack driving force and a drop in temperature, resulting in a decrease in fracture toughness. The expert explains that, according to the Griffith criterion, the specimen will ultimately fail due to the applied force being greater than the resistance of the material. The expert recommends further reading on fracture mechanics for a better understanding of this topic.
YohannM
Hello all,
It seems like a fairly straightforward question but I cannot find any information in the literature.
Let's suppose we apply a crack driving force K1=45 MPa.m^0.5 to a notched specimen with an upper shelf fracture toughness K_mat = 50 MPa.m^0.5 at room temperature T0=20 oC.
Under a constant K1=45 MPa.m^0.5 (let's ignore the effect of thermal expansion here), the temperature drops to T1=-10 oC and the fracture toughness of the material is now K_mat=40 MPa.m^0.5 (now lower shelf).
Is the specimen going to fail ? Intuitively I would think that it is the case but some people argued that if the loading occurs prior to the drop in toughness the specimen will NOT fail.
Could you please suggest some references describing similar experiments/theoretical analyses ?
Thanks for your help,
Yohann
Dear Yohann,
Thank you for your question. To answer it, we need to consider the concept of fracture toughness and how it relates to crack propagation. Fracture toughness is a material property that describes the resistance of a material to crack propagation. It is typically represented by the symbol K, and has units of MPa.m^0.5.
In your scenario, the notch in the specimen acts as a pre-existing crack. When a force, represented by K1, is applied to the specimen, it creates a driving force for the crack to propagate. The fracture toughness of the material, represented by K_mat, determines how resistant the material is to crack propagation. In this case, K_mat=50 MPa.m^0.5 at room temperature T0=20 oC.
Now, when the temperature drops to T1=-10 oC, the fracture toughness of the material decreases to K_mat=40 MPa.m^0.5. This means that the material is now less resistant to crack propagation than at room temperature. However, the applied force K1 remains the same. This means that the driving force for crack propagation is greater than the resistance of the material to crack propagation. In other words, the crack will continue to propagate and the specimen will ultimately fail.
This is supported by the concept of the Griffith criterion, which states that a material will fail when the applied stress exceeds the critical stress required to propagate an existing crack. In your scenario, the applied stress (represented by K1) remains constant, while the critical stress (represented by K_mat) decreases. Therefore, failure is inevitable.
I hope this helps to answer your question. For further reading on this topic, I recommend the following references:
1. "Fracture Mechanics: Fundamentals and Applications" by T.L. Anderson
2. "Introduction to Fracture Mechanics" by D.R. Harington
3. "Fracture and Fatigue Control in Structures: Applications of Fracture Mechanics" by R.W. Hertzberg
Best of luck with your research.
FAQ: Notched specimen under constant K and temperature gradient
What is a notched specimen?
A notched specimen is a type of material sample that has a small cut or notch intentionally made in it. This notch serves as a stress concentration point and is used in experiments to study the behavior of materials under different conditions.
What is constant K in relation to notched specimens?
Constant K refers to a specific stress intensity factor (K) that is kept constant during an experiment on a notched specimen. This allows researchers to measure the effects of other variables, such as temperature or loading rate, on the behavior of the specimen.
How is a temperature gradient applied to a notched specimen?
A temperature gradient is applied to a notched specimen through the use of a heating or cooling apparatus. This can be done by heating or cooling the entire specimen or by creating a gradient within the material itself, typically by using a hot or cold wire.
What types of materials are commonly used in experiments on notched specimens?
Notched specimens can be made from a variety of materials, including metals, polymers, and composites. The choice of material depends on the specific research question being addressed and the properties that need to be studied.
What insights can be gained from studying notched specimens under constant K and temperature gradient?
Studying notched specimens under constant K and temperature gradient can provide valuable insights into the fracture behavior and durability of materials. This information can be used to improve the design and performance of various products and structures, such as aircraft components and medical implants.
