MHB Notyo's question at Yahoo Answers regarding related rates
  • Thread starter Thread starter MarkFL
    Related rates
Gravel is being dumped from a conveyor belt at a rate of 30 ft³/min, forming a conical pile where the base diameter equals the height. The volume of the pile can be expressed as V = (1/12)πh³. By differentiating this volume with respect to time, the relationship between the rate of change of height and volume is established as dV/dt = (1/4)πh²(dh/dt). Substituting the known values, the rate at which the height of the pile increases when it is 12 ft high is calculated to be approximately 0.27 ft/min. This mathematical approach effectively solves the related rates problem presented.
MarkFL
MHB
Here is the question:
Gravel is being dumped from a conveyor belt at a rate of 30 ft3/min, and its coarseness is such that it...?
Gravel is being dumped from a conveyor belt at a rate of 30 ft3/min, and its coarseness is such that it forms a pile in the shape of a cone whose base diameter and height are always equal. How fast is the height of the pile increasing when the pile is 12 ft high? (Round your answer to two decimal places.)
___3.9, 12
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Notyo,
The statement:
"Gravel is being dumped from a conveyor belt at a rate of 30 ft3/min"
tells us regarding the rate of change of the volume of the pile of gravel:
$$\frac{dV}{dt}=30\frac{\text{ft}^3}{\text{min}}$$
That is, the volume of the pile is increasing at a rate of 30 cubic feet per minute.
The statement:
"it forms a pile in the shape of a cone whose base diameter and height are always equal"
tells us:
$$V=\frac{1}{3}\pi \left(\frac{h}{2} \right)^2(h)=\frac{1}{12}\pi h^3$$
This comes from the formula for the volume of a cone, where the base radius is equal to half the height.
Now, if we implicitly differentiate this equation with respect to time $t$, we obtain:
$$\frac{dV}{dt}=\frac{1}{4}\pi h^2\frac{dh}{dt}$$
Since we are asked to find how fast the height of the pile is increasing, we want to solve for $$\frac{dh}{dt}$$:
$$\frac{dh}{dt}=\frac{4}{\pi h^2}\frac{dV}{dt}$$
Now, using the given data:
$$\frac{dV}{dt}=30\frac{\text{ft}^3}{\text{min}},\,h=12\text{ ft}$$
we find:
$$\frac{dh}{dt}=\frac{4}{\pi \left(12\text{ ft} \right)^2}\left(30\frac{\text{ft}^3}{\text{min}} \right)=\frac{5}{6\pi}\frac{\text{ft}}{\text{min}}\approx0.265258238486492\frac{\text{ft}}{\text{min}}$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
