MHB NP Problems: Weighted Vertex Cover vs Weighted Independent Set
The discussion revolves around a theorem connecting independent sets and vertex covers in graphs, specifically addressing the scenario where vertices have positive integer weights. It posits that if S is an independent set with maximum weight, then the complement V - S should be a vertex cover with minimum weight. The argument presented demonstrates that if S is indeed a maximum weight independent set, then any alternative vertex cover T with a lower weight would lead to a contradiction regarding the maximality of S. This reasoning is applied in both directions, confirming that the properties of maximum weight independent sets and minimum weight vertex covers are intrinsically linked under the conditions specified.
JohnDoe2013
There is a Theorem that states that if G = (V, E) is a graph, then S is an independent set $\Leftarrow\Rightarrow$ V - S is a vertex cover.
Suppose the vertices have positive integer weights. Does it follow from the theorem that:
S is an independent set with maximum weight $\Leftarrow\Rightarrow$ V - S is a vertex cover with minimum weight?
Technology news on Phys.org
I think so. If $S\subseteq V$, let $w(S)$ denote the sum of weights of vertices is $S$, and let $W=w(V)$. Suppose that $S$ is an independent set with maximum weight, but $V-S$ is not minimal, i.e., there exists a $T\subseteq V$ such that $T$ is a vertex cover and $w(T)<w(V-S)=W-w(S)$. Then $w(S)<W-w(T)=w(V-T)$ and $V-T$ is an independent set, a contradiction with maximality of $S$. The other direction is shown similarly.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
