MHB N's questions at Yahoo Answers regarding hydrostatic forces
The discussion revolves around calculating hydrostatic forces on different parts of a swimming pool with an inclined bottom. Key formulas are derived for hydrostatic force on submerged rectangles and triangles, which are then applied to estimate forces on the shallow end (5000 lb), deep end (approximately 15313 lb), one side (totaling 21250 lb), and the bottom of the pool (approximately 69519 lb). The calculations utilize the weight density of water and the dimensions of the pool. These estimates provide a comprehensive understanding of hydrostatic forces acting on various surfaces in the pool.
MarkFL
MHB
Here are the questions:
Hard calculus question involving hydrostatic force?
A swimming pool is 10 ft wide and 20 ft long and its bottom is an inclined plane, the shallow end having a depth of 4 ft and the deep end, 7 ft. Assume the pool is full of water. (Round your answers to the nearest whole number. Recall that the weight density of water is 62.5 lb/ft3.)
(a) Estimate the hydrostatic force on the shallow end.
?? lb
(b) Estimate the hydrostatic force on the deep end.
? lb
(c) Estimate the hydrostatic force on one of the sides.
?? lb
(d) Estimate the hydrostatic force on the bottom of the pool.
?? lb
Please answer all 4 questions. Thanks
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello N,
Let's develop some general formulas which we can use to answer the questions. First, let's find the hydrostatic force on a vertically submerged rectangle, whose width is $w$ and height is $h$. If we orient a vertical $x$-axis along one side of the rectangle, with the origin at the surface and the positive direction down, we may compute the force along one horizontal elemental rectangle having area $A(x)$ making up the entire rectangle as:
$$dF=\rho xA(x)$$
The area of this elemental rectangle is its width at $x$ times its height $dx$, hence:
$$dF=\rho xw(x)\,dx$$
where:
$$w(x)=w$$ (the width is constant for a rectangle)
And so we have:
$$dF=\rho w x\,dx$$
Now, if the top edge of the rectangle is at $x=x_1$ and the bottom edge is at $x=x_2$, then by summing all of the elements of the force, we find:
$$F=\rho w\int_{x_1}^{x_2}x\,dx$$
Applying the FTOC, we obtain:
$$F=\frac{\rho w}{2}\left[x^2 \right]_{x_1}^{x_2}=\frac{\rho w}{2}\left(x_2^2-x_1^2 \right)$$
Since the height $h$ of the rectangle is $$h=x_2-x_1$$, we may write:
(1) $$F=\frac{\rho wh}{2}\left(2x_1+h \right)$$
Next, let's consider the hydrostatic force on a right triangle whose vertical leg lies along the $x$-axis. Let the horizontal leg, the base of the triangle, be of length $b$, and the vertical leg, the altitude of the triangle be of length $h$.
We may begin as before, computing the elemental force:
This time, the width of the triangle varies with the depth, and does so linearly. At a depth of $x=x_1$, we have $w(x)=0$ and at a depth of $x=x_1+h$, we have $w(x)=b$. Hence:
$$w(x)=\frac{b}{h}\left(x-x_1 \right)$$
And this allows us to write:
$$dF=\frac{\rho b}{h} x\left(x-x_1 \right)\,dx$$
$$dF=\frac{\rho b}{h}\left(x^2-x_1x \right)\,dx$$
Summing all of these elements of force, we find:
$$F=\frac{\rho b}{h}\int_{x_1}^{x_1+h} x^2-x_1x\,dx$$
Applying the FTOC, we find:
$$F=\frac{\rho b}{6h}\left[x^2\left(2x-3x_1 \right) \right]_{x_1}^{x_1+h}=\frac{\rho b}{6h}\left(\left(x_1+h \right)^2\left(2\left(x_1+h \right)-3x_1 \right)-\left(x_1 \right)^2\left(2\left(x_1 \right)-3x_1 \right) \right)=$$
$$\frac{\rho b}{6h}\left(\left(x_1+h \right)^2\left(2h-x_1 \right)+x_1^3 \right)=\frac{\rho bh}{6}\left(3x_1+2h \right)$$
And so we have for the right triangle:
(2) $$F=\frac{\rho bh}{6}\left(3x_1+2h \right)$$
Finally, let's consider a rectangle of width $w$ and height $h$ submerged at an angle such that the rectangle is an inclined plane. We may orient an $x$-axis that runs down the surface of the plane, parallel to its height, and whose origin is at the upper edge. Let $d(x)$ be the depth of the fluid, where $d(0)=d_1$ is the depth of the upper edge and $d\left(h \right)=d_2$ is the depth of the lower edge. We may then state:
$$d(x)=\frac{d_2-d_1}{h}x+d_1$$
$$dF=\rho w \left(\frac{d_2-d_1}{h}x+d_1 \right)\,dx$$
Summing the elements, we obtain:
$$F=\rho w\int_0^{h} \frac{d_2-d_1}{h}x+d_1\,dx$$
Application of the FTOC gives us:
$$F=\rho w\left[\frac{d_2-d_1}{2h}x^2+d_1x \right]_0^{h}=\rho w\left(\frac{d_2-d_1}{2h}h^2+d_1h \right)=\rho w\left(\frac{d_2h+d_1h}{2} \right)=\frac{\rho wh\left(d_1+d_2 \right)}{2}$$
If $\ell$ is the horizontal distance through which the plane occupies, then by Pythagoras, we may state:
$$h=\sqrt{\ell^2+\left(d_1-d_1 \right)^2}$$
And so we may state:
(3) $$F=\frac{\rho w\sqrt{\ell^2+\left(d_1-d_1 \right)^2}\left(d_1+d_2 \right)}{2}$$
We now have sufficient formulas to answer the questions.
We may use (1) where:
$$\rho=\frac{125}{2}\frac{\text{lb}}{\text{ft}^3},\,w=10\text{ ft},\,h=4\text{ ft},\,x_1=0\text{ ft}$$
Hence:
$$F=\frac{\left(\frac{125}{2}\frac{\text{lb}}{\text{ft}^3} \right)\left(10\text{ ft} \right)\left(4\text{ ft} \right)}{2}\left(2\left(0\text{ ft} \right)+4\text{ ft} \right)=5000\text{ lb}$$
$$\rho=\frac{125}{2}\frac{\text{lb}}{\text{ft}^3},\,w=10\text{ ft},\,h=7\text{ ft},\,x_1=0\text{ ft}$$
Hence:
$$F=\frac{\left(\frac{125}{2}\frac{\text{lb}}{\text{ft}^3} \right)\left(10\text{ ft} \right)\left(7\text{ ft} \right)}{2}\left(2\left(0\text{ ft} \right)+7\text{ ft} \right)=15312.5\text{ lb}\approx15313\text{ lb}$$
We may first consider the rectangular portion of the side, and using (1) where:
$$\rho=\frac{125}{2}\frac{\text{lb}}{\text{ft}^3},\,w=20\text{ ft},\,h=4\text{ ft},\,x_1=0\text{ ft}$$
Hence:
$$F_1=\frac{\left(\frac{125}{2}\frac{\text{lb}}{ \text{ft}^3} \right)\left(20\text{ ft} \right)\left(4\text{ ft} \right)}{2}\left(2\left(0\text{ ft} \right)+4\text{ ft} \right)=10000\text{ lb}$$
Now for the triangular portion we may use (2) where:
$$\rho=\frac{125}{2}\frac{\text{lb}}{\text{ft}^3},\,b=20\text{ ft},\,h=3\text{ ft},\,x_1=4\text{ ft}$$
$$F_2=\frac{\left(\frac{125}{2}\frac{\text{lb}}{ \text{ft}^3} \right)\left(20\text{ ft} \right)\left(3\text{ ft} \right)}{6}\left(3\left(4\text{ ft} \right)+2\left(3\text{ ft} \right) \right)=11250\text{ lb}$$
Thus the total force exerted on one of the sides is:
$$F=F_1+F_2=21250\text{ lb}$$
Here we may use (3) where:
$$\rho=\frac{125}{2}\frac{\text{lb}}{\text{ft}^3},\,w=10\text{ ft},\,\ell=20\text{ ft},\,d_1=4\text{ ft},\,d_2=7\text{ ft}$$
$$F=\frac{\left(\frac{125}{2}\frac{\text{lb}}{ \text{ft}^3} \right)\left(10\text{ ft} \right)\sqrt{\left(20\text{ ft} \right)^2+\left(7\text{ ft}-4\text{ ft} \right)^2}\left(4\text{ ft}+7\text{ ft} \right)}{2}=\frac{6875}{2}\sqrt{409}\text{ lb}\approx69519\text{ lb}$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
