Nuclear binding FORCE or ENERGY?
In summary, the discussion is about the concept of energy and force in relation to the nucleus of an atom. While force is a classical physics concept, in quantum mechanics, energy is the more important quantity. The energy being referred to in this context is binding energy, which is what keeps the nucleons together to form a nucleus. The terms "strong force" and "weak force" are used in a historical context and are not meant to be interpreted in the classical sense. They are more accurately described as interactions.
Sophrosyne
128
I was reading that the reason the nucleus of the atom is so heavy is that there is so much energy being used to keep the nucleons together with the strong nuclear force, and energy=mass. I can understand that. But it is energy which equals mass, not force, right? The strong nuclear force is just exerting a force to keep the nucleons together, not energy. The force may translate potential into kinetic energy if it was actually doing work across a distance. But these nucleons aren't going anywhere. They are stationary. So why is there talk of energy?
Actually, force is a classical physics concept and it has no equivalent in quantum theory. In quantum mechanics, the quantity that can be measured are called 'observables' and are defined, They include position, momentum, angular momentum and, most importantly, energy. The importance of energy is that, no matter what the system is, the stationary states (i.e. allowed quantum states) are characterized by a definite energy value. Other quantities may or may not be well defined for quantum states but that depends on details.
You say that the nucleons aren't going anywhere, so why talk about energy. Well, the energy in question is binding energy. That is the difference between all the nucleons separate and put together to form a nucleus of an atom.
In a way, this is something like binding energy that keeps you on the surface of the Earth. You are not leaving the Earth, you are stuck to being on the surface. If you want to go into space, you have to reach the escape velocity (that is 11.2 km/s), therefore the energy binding you to Earth is (1/2)* your mass * (square of escape velocity).
Likes Sophrosyne
I see. That makes sense. Thank you.
So then when there is talk of strong or weak nuclear FORCE, is it safe to say that that term "force" there is not really being used in the classical physics sense? It seems to be more of a sense of "interaction". Correct?
Likes Dale
Correct. "Strong force", "weak force", "electromagnetic force" in the context of elementary particle and nuclear physics should be understood as historical linguistic artifacts. When physicists started studying the strong and weak interactions nearly a hundred years ago, during the same period that quantum theory itself was being developed with great struggle, their background was of course in classical physics. So they first tried to explain things classically. When that failed, they continued to use classical terms in connection with the quantum concepts that replaced the classical ones.
Likes dlgoff
OK. That’s making more sense now. Thanks.
Related to Nuclear binding FORCE or ENERGY?
1. What is nuclear binding force?
Nuclear binding force is the force that holds the nucleus of an atom together. It is a strong attractive force between the protons and neutrons in the nucleus, and it is responsible for the stability of an atom.
2. How does nuclear binding force work?
Nuclear binding force is a result of the strong nuclear interaction, which is one of the four fundamental forces in nature. This force is mediated by particles called gluons and is responsible for binding the quarks inside protons and neutrons, as well as binding the protons and neutrons together in the nucleus.
3. What is the difference between nuclear binding force and nuclear energy?
Nuclear binding force refers to the force that holds the nucleus together, while nuclear energy refers to the energy released during nuclear reactions, such as nuclear fusion or fission. Nuclear binding force is a fundamental force, while nuclear energy is a result of the conversion of mass into energy.
4. How does nuclear binding energy affect the stability of an atom?
Nuclear binding energy is the amount of energy required to break apart the nucleus of an atom. The higher the nuclear binding energy, the more stable the atom is. This is because the strong nuclear force is stronger than the repulsive force between the positively charged protons in the nucleus.
5. Can nuclear binding energy be harnessed for practical use?
Yes, nuclear binding energy can be harnessed for practical use in nuclear power plants. The energy released during nuclear reactions can be used to generate electricity. However, the process of harnessing nuclear energy must be carefully controlled to avoid potential dangers and risks associated with nuclear radiation.
