Nuclear Decay Earth Sun Distance
In summary, the conversation discusses an interesting observation that nuclear decay rates change depending on the Earth's distance from the sun. The observation supports the idea that there is a build up and build down associated with whatever is causing the change. One hypothesis is that solar neutrinos play a role, but the phase lag between the affect and the distance of the Earth from the sun does not support this. The conversation also mentions unexplained fluctuations in nuclear decay rates that are correlated with the distance between the Earth and the sun. This correlation is seen in multiple experiments and suggests that discrepancies in published half-life determinations may be due to differences in solar activity or seasonal variations in fundamental constants.
Saul
271
This is an interesting observation to explain. Nuclear decay rates change depending on the Earth's distance from the sun.
The logical conclusion is some solar parameter directly affects the Earth in a manner that affects nuclear decay rates.
It is interesting to note that there is a phase lag. That is to say there is a delay in the affect to reach peak and there is a delay in the affect to reach minimum. That observation supports the assertion that there is a build up and a build down associated with what every is causing what is observed. One hypothesis presented in the paper is that solar neutrinos somehow change nuclear decay rates. A problem with that hypothesis is that as neutrinos travel at the speed of light and do not build up or build down, there would be no delay if neutrinos were the cause. The neutrino hypothesis does not explain the phase lag.
Curiously the sun our nearest star is not understood. There are multiple sets of solar observations that do not have an explanation and that concern fundamental solar processes.
http://arxiv.org/abs/0808.3283
Evidence for Correlations Between Nuclear Decay Rates and Earth-Sun Distance
Unexplained periodic fluctuations in the decay rates of Si-32 and Ra-226 have been reported by groups at Brookhaven National Laboratory (Si-32), and at the Physikalisch-Technische-Bundesandstalt in Germany (Ra-226). We show from an analysis of the raw data in these experiments that the observed fluctuations are strongly correlated in time, not only with each other, but also with the distance between the Earth and the Sun. Some implications of these results are also discussed, including the suggestion that discrepancies in published half-life determinations for these and other nuclides may be attributable in part to differences in solar activity during the course of the various experiments, or to seasonal variations in fundamental constants.
This experiment, which extended over 15 years, overlapped in time with the BNL experiment for approximately 2 years, and exhibited annual fluctuations in the 226Ra data similar to those seen at BNL. Figure 3 exhibits the PTB data as a 5 point rolling average, and it is evident from the figure that the PTB data closely track the annual variation of 1/R2. The Pearson correlation coefficient r for the data in Fig. 3 is r=0.66 for N=1968 data points, corresponding to a formal probability of 2×10−246 that this correlation could arise from two data sets which were uncorrelated. As in the case of the BNL data, there is also a suggestion of a phase shift between 1/R2 and the PTB data (see below), although this phase shift appears to be smaller than for the BNL data.
Astronomy news on Phys.org
Related to Nuclear Decay Earth Sun Distance
1. What is nuclear decay and how does it affect the Earth-Sun distance?
Nuclear decay is the process by which an unstable atomic nucleus loses energy by emitting radiation. This affects the Earth-Sun distance because the Sun's energy is produced by nuclear fusion, which causes the Sun to slowly lose mass and therefore, decrease its gravitational pull on the Earth. This results in a gradual increase in the Earth-Sun distance over time.
2. How does the Earth-Sun distance impact nuclear decay?
The Earth-Sun distance does not directly impact nuclear decay. However, it is indirectly affected as the Earth-Sun distance affects the amount of solar radiation that reaches the Earth. This radiation can cause changes in the rate of nuclear decay in certain materials, such as carbon-14 used in radiocarbon dating.
3. How is the Earth-Sun distance measured in relation to nuclear decay?
The Earth-Sun distance is measured using astronomical units (AU), which is the average distance between the Earth and the Sun. This distance is constantly changing due to the Earth's elliptical orbit around the Sun, but it is typically considered to be about 149.6 million kilometers or 93 million miles.
4. Can nuclear decay affect the Earth-Sun distance in a significant way?
No, nuclear decay does not have a significant impact on the Earth-Sun distance. The decrease in the Sun's mass due to nuclear fusion is very small and the Earth's orbit is also affected by other factors, such as the gravitational pull of other planets in our solar system.
5. How does nuclear decay relate to the age of the Earth-Sun system?
Nuclear decay is closely related to the age of the Earth-Sun system as it is one of the key processes that has shaped our solar system. The energy produced by nuclear fusion in the Sun has sustained life on Earth for billions of years and the gradual decrease in the Sun's mass over time has had an impact on the Earth's orbit and the overall stability of our solar system.
  • Astronomy and Astrophysics
10K
  • Beyond the Standard Models
  • Electromagnetism
