Nuclear-Electric SSTO Vehicle: Best Propulsion Mechanism?
In summary, nuclear electric propulsion seems to be the safest and most efficient way to get to orbit, with the potential to replace traditional fuels. There are several different technologies being developed, but MHD seems to be the most promising so far.
sanman
745
24
I've been fascinated by the idea of using a nuclear reactor (either pebble-bed or particle-bed)as a powerplant for an aerospace vehicle, but of course there is the problem of coupling the thermal energy to the propellant flow by direct contact without having bits of radioactive debris from the reactor coming out in the exhaust. MHD at least avoids this, by using electromagnetism to couple the reactor's power with the flowstream, instead of direct contact. To me, this is obviously the safest way to use nuclear power to get to orbit. My understanding is that NASA's recently discontinued Prometheus reactor was based on the SAFE-400 pebble bed design.
http://en.wikipedia.org/wiki/Nuclear_electric_rocket
I came across this mention of the Ajax, which was a Soviet design for a nuclear-powered MagnetoHydroDynamic hypersonic vehicle, apparently sled-launched (I don't know why they didn't have something that would take off under its own power)
http://translate.google.com/transla...ets/ajax/ajax.htm&sl=ru&tl=en&history_state0=
I was further thinking that ionization of the oncoming airstream would not only turn it into a good propellant, but would improve its flow characteristics as well, reducing frictional heating and turbulence. We also now know that control surfaces can be devised which use electrostatics to affect the slipstream around the aircraft even at high mach conditions.
I've read that electrical control surfaces can even be used to reduce the stall speed of conventional aircraft.
Another technology I was reading about was PIT (Pulsed Inductive Thruster) which seems to me to be the plasma-electric equivalent of the Pulse Detonation Engine.
http://en.wikipedia.org/wiki/Pulsed_inductive_thruster
Like PDEs, this seems to be an interestingly flexible form of propulsion, which seems very well suited to the instant-on-off cyclability of electric current.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19930023164_1993023164.pdf
It seems to me that with PIT, you could use it in a DC-X type of VTVL rocket, so that you could take off and land on Earth, Moon and Mars in the same way regardless.
Unlike the hypersonic flight regime, you'd quickly clear the atmosphere and fly friction-free to orbit, and similarly you could also make powered landings.
I'm then wondering what the opinions are on which is the superior form of nuclear-electric propulsion. For example, is it PIT or MHD - or is it something else? What are the pro's and cons of each? Comments?
Here's more:
http://trs-new.jpl.nasa.gov/dspace/bitstream/2014/38357/1/05-1846.pdf
For aircraft you might consider driving a generator and using electric superconducting turbofans as discussed https://www.physicsforums.com/showpost.php?p=2292842&postcount=14", since if you have nuclear you might see performance like this:
-737 traditional fuel load = 26 tons
-737 engine power cruise (x2): 5.5MW [24kN * 228m/s]
-Replace fuel load w/ Hyperion 25MW(e) small reactor. Weight, size: 15-20 tons, 1.5M OD x 2M
Range: Five years aloft
One conversion system I'd read about was called AMTEC (Alkali Metal Thermo Electric Conversion), which is supposed to be feasible for operation with nuclear outlet temperatures upto ~1500degC.
http://en.wikipedia.org/wiki/Alkali-metal_thermal_to_electric_converter
I'd also wonder if buckyonions could become a useful propellant for electric thrust, with the possibility of good coupling with the Lorentz force.
Related to Nuclear-Electric SSTO Vehicle: Best Propulsion Mechanism?
1. What is a nuclear-electric SSTO vehicle?
A nuclear-electric SSTO (single-stage-to-orbit) vehicle is a type of spacecraft that is designed to reach orbit without any staging or separation of its components. It is powered by a combination of nuclear and electric propulsion, which allows it to carry heavy payloads and achieve high speeds in space.
2. How does the nuclear-electric propulsion system work?
The nuclear-electric propulsion system works by using a nuclear reactor to generate heat, which is then converted into electricity. This electricity is used to power an ion thruster, which produces thrust by accelerating and expelling ions at high speeds. The ions are then directed out of the spacecraft, providing propulsion.
3. What are the advantages of using nuclear-electric propulsion on an SSTO vehicle?
There are several advantages of using nuclear-electric propulsion on an SSTO vehicle. Firstly, it allows for a higher specific impulse (a measure of efficiency) compared to traditional chemical propulsion systems, meaning the vehicle can achieve higher speeds. Secondly, it allows for a longer duration of thrust, meaning the vehicle can travel longer distances. Additionally, nuclear-electric propulsion is more efficient and requires less propellant, allowing for a larger payload capacity.
4. Are there any safety concerns with using nuclear propulsion on an SSTO vehicle?
Nuclear propulsion on an SSTO vehicle does come with some safety concerns. The use of nuclear materials in space carries the risk of accidental release or contamination, which could have environmental and health consequences. However, strict safety protocols and regulations are in place to minimize these risks, and modern nuclear reactors are designed with safety as a top priority.
5. How close are we to developing a nuclear-electric SSTO vehicle?
While there have been studies and research conducted on the feasibility of a nuclear-electric SSTO vehicle, there are currently no operational vehicles using this propulsion system. However, with advancements in technology and continued research, it is possible that we could see a nuclear-electric SSTO vehicle in the future.
  • Aerospace Engineering
  • General Engineering
26K
10K
  • Mechanical Engineering
