Nuclear Explosion Space Bright or Dim Flash
In summary, a nuclear explosion in deep space would emit a large burst of energy, with photons ranging from Gamma to Radio being released. The explosion would also produce Alpha and Beta rays, neutrons, and potentially heavier nuclei. All of these particles would be emitted in a spherical shape. There would be no mushroom cloud or shockwave due to the lack of atmosphere in deep space. The heat produced would not be from the temperature of gas, but from the infrared photons. The explosion would also produce hydrogen gas, and most of the particles would escape the Earth's gravitational field.
Albertgauss
37
Hi all,
I think there is a post on this somewhere that is accessible via google but somehow too hard to find on this site. Anyway, if a nuclear explosion went off in deep space, I think the following would happen:
There would be a large burst of energy. All photons from Gamma to Radio would be emitted. The light from a nuclear blast is intrinsic to the energy of the nuclear explosion itself, so one should also see a bright fireball in the optical range. It should also persist for several seconds or more. A nuclear blast in the atmosphere of the Earth certainly persists for dozens of seconds, so I would expect a nuclear explosion in space to exist on a comparable timescale. It would be like a mini-sun for up to a minute, maybe 30 secs, I'm not sure, but it would be on this timescale.
There would also be Alpha and Beta rays, and neutrons, so there would be large numbers of these particles released. They wouldn't be seen with the naked eye, but they would cook anything nearby much more quickly and strongly than a microwave. Finally, there might be some heavier nuclei ejected from the nuclear erxplosion.
All expulsion of matter or photons would be spherical.
There would be no mushroom cloud, shockwave, sound, etc. as such effects would need an atmosphere, and that is completely lacking in deep space.
There would be heat, but it would NOT be due to the temperature of any gas; it would be the heat of the infrared photons produced by the energy of the explosion.
How am I doing with imagining what a nuclear blast would look like in space? Other posts on the internet mentioned a dim flash that is over quickly due to a lack of atmosphere, but I think this is incorrect. I think the trememndous energy in a nuclear explosion would have plenty of energy for plenty of optical photons.
Google "Starfish Prime" to see video and color images of above-atmosphere nuclear shot.
I think that a few minutes after the blast you would have a lot of hydrogen gas. The neutrons can decay into protons that combine with the beta rays to form hydrogen.
Much of the electrically-neutral matter (including neutral hydrogen and neutrons) would have multi-keV energies (β>0.005) or MeV energies and quickly escape the Earth's gravitational field. Most of the charged particles (including ions, protons, and electrons) would be trapped by the Earth's magnetic field, hit the upper atmosphere, and create spectacular Aurora Borealis. Gammas and x-rays would be line of sight into 4π.
"Deep space" is not close to the Earth - and starfish prime was still close to the earth.
But it comes from the primary explosion only, which is of the order of microseconds to milliseconds. Afterwards, you have a cloud of many isolated, fast particles expanding from the point of the explosion in all directions. Not many options to generate light.
A nuclear blast in or close to the atmosphere can heat the air, which can emit light afterwards.
You can design nuclear weapons to be aspherical. The total momentum is (in the frame of the warhead) zero, but it can emit more energy in two opposite directions, for example.
Correct
And all the other particles, as you already mentioned.
Nuclear weapons produce a lot of neutrons in terms of nuclear reactions. But in terms of weight, don't expect more than some grams, rapidly flying in all directions. After one neutron lifetime, they are already (many) thousands of kilometers away from the explosion.
Related to Nuclear Explosion Space Bright or Dim Flash
1. What is a nuclear explosion space bright or dim flash?
A nuclear explosion space bright or dim flash is a phenomenon that occurs during a nuclear explosion in space. It is a momentary burst of intense light that is caused by the intense energy released from the explosion.
2. How bright is a nuclear explosion space bright or dim flash?
The brightness of a nuclear explosion space bright or dim flash can vary depending on the size and intensity of the explosion. However, it can reach levels of several million times brighter than the sun.
3. Can a nuclear explosion space bright or dim flash be seen from Earth?
Yes, a nuclear explosion space bright or dim flash can be seen from Earth if it occurs in the line of sight of an observer. However, it may not be visible to the naked eye and may require specialized equipment to detect.
4. What is the difference between a bright and dim flash in a nuclear explosion in space?
The difference between a bright and dim flash in a nuclear explosion in space is the amount of light emitted. A bright flash is more intense and can last for a longer period of time, while a dim flash may be shorter in duration and less intense.
5. Are there any potential dangers associated with a nuclear explosion space bright or dim flash?
Yes, a nuclear explosion space bright or dim flash can have potential dangers, such as damaging satellites and other spacecraft, disrupting communication and navigation systems, and causing temporary blindness for those who witness it. It can also have long-term effects on the Earth's atmosphere and environment.
17K
