Nuclear fission and amount of U-235 used
That is the same answer you got; so your method is correct.In summary, in a power plant with a heat energy capacity of 2050 MW, there are approximately 6.4*10^19 fissions per second and 1.82*10^27 fissions per year. This results in the consumption of 713.4 kg of U-235 per year.
FinSanity
[SOLVED] Nuclear fission and amount of U-235 used
At the fission of a U-235 atom about 200 MeV of energy is released. How many fissions occur in 1 second in an power plant which has the heat energy capacity of 2050 MW? How much U-235 is consumed in one year (330 days)?
U-235 -> 8,2 * 10^13 J/kg
q = 200MeV
Ø = 2050 MW
Elementary charge = 1,602*10^-19 C
kWH -> J 1 kWH = 3,6 * 10^6 J
Ø = n' * q => n' = Ø / q = 2050 * 10^6 / ((200*10^6) * (1,602*10^-19) =
6,4*10^19 fissions / second
2050000 * 3,6 = 7,38 * 10^12 J/h
7,38 *10^12 J/h * 24 * 330 = 5,85 * 10^16 J/year
(5,85 * 10^16) / (8,2 * 10^13) = 713,4 kg/year
Are these correct? I'm not sure if the way I calculated the consumption of U-235 per year is correct.
I agree with this result.
I think you dropped a few zeroes in typing your 2,050,000,000 W (2050 MW), but the figure on that line is right. But on the next line, why are there 330 days in a year? (EDIT: Sorry, I missed the specification in the problem.)
Another way to get to the answer is this:
You found that there are 6.4 · 10^19 fissions per second. Therefore, that many U-235 nuclei are fissioning in one second; so there are (6.4 · 10^19)(3600)(24)(330) = 1.82 · 10^27 nuclei fissioning per year.
This is (2.02 · 10^27)/(6.02 · 10^23) = 3030 moles of U-235 consumed in a year, which is 3030 · 235 = 712,300 gm or 712.3 kg of U-235 per year.
FAQ: Nuclear fission and amount of U-235 used
What is nuclear fission?
Nuclear fission is a process in which the nucleus of an atom splits into smaller parts, releasing a large amount of energy. This process is used in nuclear power plants to generate electricity.
How does nuclear fission occur?
Nuclear fission occurs when a neutron collides with the nucleus of a uranium-235 atom, causing it to split into two smaller atoms and releasing additional neutrons. These neutrons can then collide with other uranium-235 atoms, causing a chain reaction.
What is the most common isotope of uranium used in nuclear fission?
The most common isotope of uranium used in nuclear fission is uranium-235. This isotope is used because it is the only naturally occurring isotope that is fissile, meaning it can sustain a nuclear chain reaction.
How much uranium-235 is typically used in a nuclear fission reaction?
In a typical nuclear fission reaction, about 3-5% of the uranium fuel is made up of uranium-235. The remaining 95-97% is made up of the non-fissile isotope uranium-238. This ratio of uranium-235 to uranium-238 is essential in maintaining a sustainable nuclear chain reaction.
What are the potential dangers of using uranium-235 in nuclear fission reactions?
One of the main dangers associated with using uranium-235 in nuclear fission reactions is the risk of nuclear accidents and radioactive contamination. Additionally, the production and disposal of nuclear waste from these reactions can also pose environmental and health hazards if not properly managed.
