Nuclear reactions and Einstein's famous formula
In summary, Einstein's theory of relativity applies to all of physics, including nuclear physics. Although there are other ways to calculate the energy difference in nuclear processes, the equation E=mc^2 still holds and is only noticeable in these processes due to their large energy differences. The binding energy in a nucleus is a result of the interaction between the strong and electromagnetic forces on the particles in the nucleus, and as the size of the nucleus increases, the binding energy per nucleon decreases, making heavy elements unstable.
JanEnClaesen
59
In high school, we calculated the reaction-energy by equating the mass difference and the energy difference with proportionality factor c².
How does Einstein's theory of relativity suddenly enter nuclear physics? It startles me because both fields developped historically completely divergent. Aren't there nuclear physical ways to calculate this energy? In retrospect, the calculations seem too simple to be true.
The theory of relativity is a universal theory. It applies to all of physics, including nuclear physics.
Sometimes calculations are both simple and true.
So is quantum mechanics...
Quantum mechanics is... (Half an answer to half a question)
My knowledge is too incomplete to ask full questions. But as far as I know, quantum mechanics relates the same variables but is not consistent with general relativity and hence might provide a different answer.
General relativity is a theory of gravity which plays no role in nuclear physics. Relativity on the other hand is a universal meta-theory that applies to all physics including nuclear physics.
I see, special relativity isn't a special case of general relativity.
No, it's more that:
1) Special relativity applies in the special case of flat space-time, whereas general relativity applies in the general case of flat or curved spacetime.
2) Although special relativity is therefore a special case of general relativity, there are a large number of problems, including just about everything at and below atomic scale, for which we don't use general relativity. That's not because it's not applicable (it is the more general theory, after all), it's because the general relativistic effects are so insignificant that we can safely ignore them.
3) SR calculations are so much simpler than GR calculations that no one ever uses GR except when it's needed.
Special relativity is a special case of general relativity since we can obtain the former by applying the latter to a flat space case. Both of those theories are instances of relativistic theories. There are other conceivable ways to apply the concepts of relativity to gravity and obtain alternate relativistic theories of gravity other than general relativity. In that sense General relativity is a special implementation of relativity to gravity. None of that matters here though because 1) gravity plays no role in nuclear physics. 2) there really isn't any obvious inconsistencies between GR and quantum mechanics. What we do have is incomplete understanding of how to apply quantum mechanics to general relativity, which is a different thing. The only situation where there appears to be a real contradiction between GR and QM is the B-hole information paradox, but that paradox - like most physical paradoxes - Is like just an apparent paradox, not a real paradox.
There are nuclear physical ways to calculate the energy difference. For instance, in nuclear fission, the energy difference is mainly (other nuclear effects enter, but are smaller) due to the difference in the Coulomb energies of the parent nucleus and its daughters.
E=mc^2 holds for any process, it is just large enough in nuclear processes to be seen.
When hydrogen burns, the mass of H_2O is less than the mass of H_2 and O, but this difference is too small to be seen.
Is the binding energy a measure of the internal motion in the nucleus?
It's a result of the interaction of the strong force and the EM force on the particles in the nucleus. If you take Hydrogen and start adding the right mix of nucleons to it you will increase the binding energy per nucleon thanks to the strong force. However, once you hit iron and nickel, adding further nucleons results in a higher binding energy per nucleon because the size of the nucleus starts to become greater than the range of the strong force. You have protons that are repelling each other through their positive charges, yet aren't attracting each other through the strong force anymore because they are too far away from each other. This is why very heavy elements are unstable. The protons start to feel massive repulsion from the combined force of every other proton in the nucleus, but they only feel the strong force from a few of the nucleons that are nearby.
Related to Nuclear reactions and Einstein's famous formula
1. What is the significance of Einstein's famous formula, E=mc2?
Einstein's famous formula, E=mc2, represents the relationship between mass (m) and energy (E). It states that mass and energy are interchangeable, and a small amount of mass can be converted into a large amount of energy, as seen in nuclear reactions.
2. How are nuclear reactions different from chemical reactions?
Nuclear reactions involve changes in the nucleus of an atom, while chemical reactions involve changes in the outer electron configurations of atoms. Nuclear reactions also release much more energy compared to chemical reactions.
3. What are the two types of nuclear reactions?
The two types of nuclear reactions are fission and fusion. Fission is the splitting of a heavy nucleus into smaller nuclei, while fusion is the combining of two light nuclei to form a heavier nucleus.
4. How are nuclear reactions used in energy production?
Nuclear reactions are used in nuclear power plants to produce electricity. The heat generated from nuclear reactions is used to produce steam, which then turns turbines to generate electricity.
5. What are the potential risks associated with nuclear reactions?
The main risks associated with nuclear reactions are radiation exposure and the potential for nuclear accidents. Radiation exposure can be harmful to human health, and nuclear accidents can have devastating effects on the environment and surrounding communities.
