Hak
- 709
- 56
- TL;DR Summary
I don't know if the Forum in which I am posting is right, if it is not please freely move my question to the Forum you think is most appropriate.
You argue that nuclear reactions occur in the Sun, which produce the energy that spreads out into space in the form of light. A friend of yours disagrees, and argues that the Sun's energy might come from the gravitational potential energy that the Sun loses as it contracts. How do you change his mind without using overly complicated arguments that he would not understand?
Do you have any arguments or ideas to make the question more elucidating? This question is emblematic of a cross-examination between a professor and some students, at the end of which the former sketches an equation saying that it is derived from the assumption that the only way energy propagates in the star is by radiative transport (i.e., photons that are absorbed and re-emitted by atoms), an assumption that is not always true:
$$\frac{dT(r)}{dr}=-\frac{3L(r)}{16 \pi al(r)cr^2T(r)^3}$$
Where a is a constant called the blackbody constant and such that the energy density in a blackbody at temperature ##T## is ##aT^4##; ##l(r)## is the free mean path of photons at distance r from the center; ##c## the speed of light.
The professor himself says it is not easy to get there: how to justify this equation? Do you have any opinions or advice on this?
At the end of it all, the professor debuts with this other question:
How to approach the question? How to understand whether it is true that matter in white dwarfs is ionized? How to understand that if the kinetic energy of particles (should be of the order of ##k_BT##) is much larger than the ionization energy, then matter is ionized?
Thank you to anyone who would like to answer me and clarify this question, which I consider complex and not at all trivial.
The fact that matter is ionized allows ions and electrons to be much closer together than they are in atoms (Bohr radius ##a=0.5 \cdot 10^{-10}m##), and the result is that some stars, including white dwarfs, have a very small radius and a very high density that could not be had if matter were not ionized.
A white dwarf, however, is a star that has run out of nuclear fuel; therefore, it slowly cools down. At some point the temperature becomes so low that matter would tend to regroup into non-ionized atoms. But to do that it would have to increase its radius and decrease its density, and this it cannot do because the change in gravitational energy it would take is greater than all the energy it has left.
So, in a sense, the star would get to a situation where it does not have enough energy to cool down again. In other words, the temperature would stop decreasing without the star being in equilibrium with the part of the universe that surrounds it, and that is obviously not possible.
