Nuclear reactor in zero gravity
In summary, nuclear reactors are used to power satellites and other space-faring vehicles because they require very little force to correct their trajectory. Freefall is the same as "no gravity," and the mechanics of a reactor operate in zero gravity or free fall. RTGs are typically used in space, and lack of gravity is not an issue for thermoelectric conversion.
ChazH
How do nuclear reactors used to power satellites and such operate in zero gravity?
Hi there,
I don't think I fully understand your question. There is absolutely no reason for heavy nuclei not to fission in zero gravity. The fission of a nucleus is a stochastic event, that depends on the potential energy of the nucleons and the nuclear strong interaction, ok mixed with a bit of quantum physics.
For powering sattelites, since they are in almost without gravity, you need very little force to correct their trajectory. Therefore, with just a little bit of power, you can deviate a satellite, and put it back into a correct trajectory.
Cheers
google "nuclear powered satellites"
here's the first hit:
http://www.fas.org/nuke/space/bennett0706.pdf
fatra2 said:
... For powering sattelites, since they are in almost without gravity, you need very little force to correct their trajectory. Therefore, with just a little bit of power, you can deviate a satellite, and put it back into a correct trajectory.
Cheers
Think of a satellite orbiting at a altitude of, say, 200 miles. The gravitational force on the satellite is (4000 / 4200)^2 or 91 percent of the force of gravity it feels at sea level. Freefall isn't the same as "no gravity."
Uh ! That's not true ! Locally, of course, everything in the satellite will behave as in gravity-free outer space.
Free fall IS the same as no gravity (apart from tiny tidal effects). That's what the equivalence principle is about.
I guess the OP wants to know how the mechanics of a reactor operates in "zero gravity" or "free fall". Of course it cannot be a BWR, and even a PWR would be hard to do, because you need gravity in those systems to separate vapor from liquid water (for a BWR, in the reactor vessel, and for a PWR, in the steam generators).
Also the workings of a cooling tower are probably jeopardized in space :wink:
What I was trying to say is, moving to a higher orbit requires nearly as much work (91% in the case of an orbit initially at 200 miles above the surface) as it does at sea level. Contrary to the previous post which says that in the absence of gravity such maneuvers require little power. Am I wrong about that?
Yes - maneuvers to put a satelite in a higher orbit require energy. So to move a sateleite from a 200km orbit to 400km requires almost as much energy as to move it from the ground to 200km - except for all the losses getting through the atmosphere.
But most satelite orbital maneuvers don't change the energy very much - they are to slightly shift the inclination of the orbit to put it over a new target or to avoid another object.
The bigger problem using reactors for thrust is that you still need a propellant which is used up - if you are going to use a reactor to heat an inert propellant and throw it out of the back to create thrust - you might as well just carry a chemical fuel. The exception to this is ion drive engines that expel charged ions at very high speed and so use very little propellant mass - but the thrust of these engines is to low for them to be practical for maneuvering satellites.
The main use of reactors in satelites is for low orbits where large solar panels would cause too much drag and you need a lot of power.
Mech_Engineer said:
Correct me if I'm wrong, but don't most space-faring vehices use Radioisotope Thermoelectric Generators (RTG) rather than full-fledged nuclear fission reactors?
From what I understand, the American SNAP-10A and Soviet RORSAT are the only fully-fledged nuclear reactors ever launched.
Correct. Nuclear power systems in space are typically RTGs, which have traditionally used isotopic decay, e.g. alpha decay of Pu-238 as a heat source.
The thermal to electrical conversion is accomplished by thermoelectric systems which are solid state, so lack of gravity is not an issue. One could use single phase cycles like a Brayton cycle, and likewise, lack of gravity is not an issue.
If one wishes to use a two-phase cycle like the Rankine cycle, it's possible, but requires a clever design to deal with the lack of bouyancy in the absence of gravity. One could spin the part of the vehicle with the power plant in order to induce 'artificial' gravity, but then one must consider the v2/r relationship.
Out in space, radiation or radiative heat transfer is the process by which heat is rejected from the system to the environment.
Ah, sorry, I thought you made the silly mistake of Jules Verne :smile:
Related to Nuclear reactor in zero gravity
1. What is a nuclear reactor in zero gravity?
A nuclear reactor in zero gravity is a type of nuclear reactor that is designed to operate in outer space or in a microgravity environment, where the force of gravity is significantly reduced or completely absent. These reactors use nuclear fission to generate heat and produce electricity, and they are primarily used to power spacecraft and space stations.
2. How does a nuclear reactor work in zero gravity?
In a nuclear reactor in zero gravity, the nuclear fuel is contained in a core that is surrounded by a neutron reflector and a heat transfer fluid. When the nuclear fuel undergoes fission, it releases energy in the form of heat, which is transferred to the heat transfer fluid. This fluid then circulates through the reactor and is used to power a turbine, which generates electricity.
3. What are the benefits of using a nuclear reactor in zero gravity?
Using a nuclear reactor in zero gravity has several benefits. It can provide a steady and reliable source of power for long-duration space missions, as it does not rely on solar energy or other external sources. It also has a higher power density and is more efficient compared to other types of power sources used in space, such as solar panels.
4. What are the potential risks of a nuclear reactor in zero gravity?
The main risk associated with a nuclear reactor in zero gravity is a potential nuclear meltdown, which could release harmful radiation into the spacecraft or space station. To mitigate this risk, these reactors are designed with multiple layers of safety features, including automatic shutdown systems and passive cooling mechanisms.
5. What advancements are being made in the development of nuclear reactors in zero gravity?
Currently, there is ongoing research and development to improve the design and safety features of nuclear reactors in zero gravity. This includes using new materials that can withstand the extreme conditions of space and developing more efficient methods for managing and disposing of nuclear waste produced by these reactors.
  • Nuclear Engineering
