Nuclear Reactors, Atom Smashers, and Particle Accelerators
In summary: You would also need a very large safe room to store all the equipment.In summary, building a particle accelerator is not easy, but it is possible with the right resources.
marshallmeyer1
What would be the difficulty of building each? I have read of Michio Kaku building an atom smasher (albeit it ruined the power flow to his house,) I have found a 200,000 volt generator so I presume that a particle accelerator would be possible, and my friend is currently working on a nuclear reactor. In addition to these, what other machines could be engineered that have something to do with physics?
That is a very bad idea.
CRTs as small particle accelerators can be built at home. Don't try this with 200kV, however.
Many things, but keep away from radioactive stuff, high-energetic particles, high voltage and other threats, if you don't have professional experience with them.
^^^ Thanks man.
There should be no problem as long as you seek advice from people who know.
i doubt you will be building a nuclear reactor at home as the critical mass requires enough radioactive material that even if you will try to get it the FBI and CIA will get you before that , but in the case of a particle accelerator all you need is design , plans circuitry etc and safe handling with high voltage and sufficient isolation from the radiation that will be produced when operating such a machine.
Now about the high voltage and radiation shielding it is a must to consult a professional before or after or in the middle of something like this.
Actually the NRC and NNSA would probably get involved.
If one builds a machine that produces radiation, there are certain thresholds at which one must notify state and federal authorities for appropriate permits.
For example -
http://dhhs.ne.gov/publichealth/Pages/puh_enh_rad_x-ray_xrindex.aspx
http://www.state.il.us/iema/radiation/xray.asp
http://www.state.nj.us/dep/rpp/brh/index.htm
http://www.doh.state.fl.us/environment/radiation/ion1.htm
In the UK - http://www.hse.gov.uk/radiation/ionising/certxray.htm
Canada - http://www.e-laws.gov.on.ca/html/regs/english/elaws_regs_900861_e.htm
With a license comes the obligation to observe mandatory safety measures, e.g.,
RADIATION SAFETY REQUIREMENTS FOR PARTICLE ACCELERATORS
http://www.crcpd.org/SSRCRs/ipart91.PDF
Nuclear reactors require special nuclear material. One must obtain licenses to construct and operate a nuclear reactor, as well as possesses special nuclear material.
Well the CIA and FBI were just an analogy for someone who would come knocking on your door when the "teapot" is starting to boil too hard.
Woa Astronuc either you have these sites written down links kept in your computer all the time or you have done some respectful effort in searching them.
Either way i think the OP got his "starters" information.
Absolutely, thanks Crazymechanic and Astronuc
also u need miles of copper wire
Related to Nuclear Reactors, Atom Smashers, and Particle Accelerators
What is a nuclear reactor?
A nuclear reactor is a device that uses controlled nuclear reactions to produce energy. The energy is generated by splitting atoms of uranium or plutonium in a process called nuclear fission.
How does a nuclear reactor work?
In a nuclear reactor, uranium atoms are bombarded with neutrons, causing them to split and release energy in the form of heat. This heat is then used to produce steam, which is used to power turbines and generate electricity.
What is an atom smasher?
An atom smasher, also known as a particle accelerator, is a large machine that accelerates particles to high speeds and collides them together. This allows scientists to study the fundamental building blocks of matter and the forces that govern them.
Why are atom smashers important?
Atom smashers are important because they allow scientists to study the smallest components of the universe and gain a deeper understanding of how it works. They also have practical applications such as in medical research and the development of new technologies.
Are nuclear reactors and atom smashers the same thing?
No, nuclear reactors and atom smashers are not the same thing. While both use nuclear reactions, their purposes and methods are different. Nuclear reactors are used to produce energy, while atom smashers are used for scientific research.
  • Nuclear Engineering
  • STEM Career Guidance
18K
