Nuclear Spin and Magnetic Resonance Imaging
In summary: As a consequence, the spins precess around the z-axis with an angle that depends on the strength of the magnetic field. They never fully align with the external magnetic field due to this inherent uncertainty. In summary, the external static magnetic field in MRI causes the magnetic dipole moments of protons to align parallel or antiparallel. Some protons align anti-parallel due to temperature and the uncertainty principle causes the protons to precess around the axis of the external field, never fully aligning with it.
Jimmy87
686
Hi pf,
Please could someone kindly answer a few questions about proton spin in the context of MRI. As I understand it when an external static magnetic field is applied to a patient the magnetic dipole moments of the protons in the hydrogen nuclei will experience a torque causing them to align with this external field. Some will align parallel and some will align antiparallel. Aswell as the alignment, the other effect this external field has is to cause the protons to precess around an axis which is aligned with the external field. I have two questions:
1) Why do some protons align anti-parallel with the external field? I get that they do this when a radio frequency pulse is sent in but before that why do some align anti-parallel when the lowest energy state is parallel?
2) What causes the protons to precess (i.e. why can't they just line up with no precession) and why do the magnetic dipole moments never fully align with the external magnetic field (there is always some angle)?
Thank you for anybody who can spare time to help answer these questions
1) Temperature. The energy difference between aligned and anti-aligned spins is diminute, and you get a Maxwell Boltzmann distribution over these two states.
2) Uncertainty principle. If spins were to align perfectly with the magnetic field, e.g. along z-axis, the component of the spin along the x and y-axis would have to vanish. But this is not possible according to the uncertainty principle which states that not both s_x and s_y can be measured without uncertainty.
Related to Nuclear Spin and Magnetic Resonance Imaging
1. What is nuclear spin and how is it related to magnetic resonance imaging (MRI)?
Nuclear spin is a property of atomic nuclei that determines their magnetic behavior. This spin can be manipulated using a strong magnetic field in MRI, allowing for the creation of detailed images of the body's internal structures.
2. How does MRI technology use nuclear spin to produce images?
In MRI, a strong magnetic field is applied to the body, causing the nuclei of certain atoms to align in a specific direction. A radiofrequency pulse is then used to excite these nuclei, causing them to emit a signal that is used to create images of the body's tissues and organs.
3. What is the difference between nuclear spin and electron spin in MRI?
Nuclear spin refers to the spin of atomic nuclei, while electron spin refers to the spin of electrons. In MRI, nuclear spin is used to produce images, while in techniques like electron paramagnetic resonance imaging (EPR), electron spin is utilized.
4. Can MRI detect different types of nuclear spin in the body?
Yes, MRI can detect different types of nuclear spin, such as hydrogen, sodium, and phosphorus. Each type of spin produces a unique signal, allowing for the visualization of specific tissues and molecules in the body.
5. Are there any risks associated with the use of nuclear spin in MRI?
No, there are no known risks associated with the use of nuclear spin in MRI. The magnetic fields used in MRI are not strong enough to cause harm to the body, and the radiofrequency pulses are at a very low energy level. However, patients with certain implanted devices, such as pacemakers, may not be able to undergo MRI due to potential interactions with the magnetic fields.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
