Nucleophilicity and basicity relationship
In summary, nucleophilicity and basicity are related concepts, but they should not be used interchangeably. While basicity is a thermodynamic property that depends on the stability of the resulting conjugate base, nucleophilicity is a kinetic property that describes the rate at which a compound can donate electrons in a reaction. The strength of a nucleophile is affected by factors such as electronegativity, polarizability, and geometry, while basicity is primarily determined by the stability of the conjugate base. Therefore, although nucleophilicity and basicity generally increase going down a column of the periodic table, there can be significant differences between the two in some cases.
Puchinita5
183
This isn't so much a homework question as a question to help me undertstand how to do my homework.
The book says that nucleophilicty roughly parallels basicity. Which makes sense since bases are electron pair donors, and an electron pair makes a nucleophile.
but then it says nucleophilicity increases going down a column of the periodic table. I understand that because of the larger valence shells going down a column means the electrons will be held less tightly so they will be more reactive. But this also goes against my intuition because I know that acidity increases going down a column as well? And since nucleophilicity should increase with basicity, this seems to be a conflicting idea to me?
Can anyone explain?
Im not entirely sure I understand what you're asking but acidity increases down a group because the bond between the conjugate base and the hydrogen gets weaker. Think of it in terms of orbital overlap. HF should be a stronger acid than HI because F is the most electronegative atom but the orbital overlap between H and F is better than H and I so H can dissociate from I more easily.
Hope this helps.
Nucleophilicity is more of a kinetic description while acidity/basicity has a lot to do with thermodynamics. That is, in organic chemistry, proton transfers occur so readily and rapidly that it's pointless to discuss the rate of reaction, just the ratio of products to reactants.
Nucleophilicity, on the other hand, speaks to how readily something will donate electrons in a nucleophile/electrophile reactions (Sn1, Sn2, Carbonyl addition, etc.). The rates of these reactions can easily be measured and are affected by things such as the electronegativity, polarizability, and geometry of a nucleophile. Cyanide and azide ions are both very good nucleophiles due to their geometry: they are small, and linear, sort of bullet-shaped.
Tertiary amines are good bases but also poor nucleophiles. They readily accept protons because of their lone electron pair, but are reluctant to add to, for example, carbonyl groups. This is one reason why they are used as acid scavengers in reactions that generate HCl, for example, but that also involve molecules that could undergo nucleophilic attack. An example off the top of my head is:
PCl3 + 3 ROH --(tertiary amine or pyridine)--> (RO)3P + 3 HCl
Really though, there are a lot of shades of grey. Nucleophilicity does parallel basicity, roughly, but one should not necessarily be used as an indicator of the other. That is, when you're looking at a compound and deciding its nucleophilicity or basicity, you should really evaluate the two independently by their separate criteria.
Related to Nucleophilicity and basicity relationship
1. What is the difference between nucleophilicity and basicity?
Nucleophilicity refers to the ability of a molecule or ion to donate an electron pair to another molecule or ion, while basicity refers to the ability of a molecule or ion to accept a proton. Nucleophilicity and basicity are related, but not interchangeable terms.
2. How are nucleophilicity and basicity related?
In general, the more basic a molecule or ion is, the more nucleophilic it is. This is because basicity is determined by the strength of the electron pair that a molecule or ion can donate, and this same electron pair is also responsible for nucleophilicity.
3. What factors affect nucleophilicity and basicity?
The size and charge of a molecule or ion are the main factors that affect its nucleophilicity and basicity. Smaller molecules or ions with a greater charge are more nucleophilic and basic than larger molecules or ions with a smaller charge.
4. How do different solvents affect the relative nucleophilicity and basicity of molecules?
Solvent polarity can affect the relative nucleophilicity and basicity of molecules. In polar solvents, nucleophilicity and basicity tend to increase, while in nonpolar solvents, they tend to decrease.
5. How can the relationship between nucleophilicity and basicity be used in chemical reactions?
The understanding of nucleophilicity and basicity is important in determining the outcome of chemical reactions. For example, in a reaction between a nucleophile and a proton, the more nucleophilic species will be the one to react and form a new bond. Similarly, in a reaction between a basic species and an acidic species, the more basic species will be the one to accept the proton and form a new bond.
  • New Member Introductions
