Null Hypothesis Waterbody - Environmental Statistics
In summary: Your Name]In summary, the conversation discusses past studies on the contamination level of a waterbody and the results of two independent studies conducted on a sample of containers from the waterbody. The first study showed a contamination level of 21.65%, while the second study showed a level of 22.78%. It is noted that these results do not necessarily indicate the effectiveness of cleaning efforts and that combining the data from both studies can provide a better understanding of the overall contamination level. However, it is important to consider potential limitations and carefully examine the data before drawing conclusions. The use of correct formulas and visual representations can also be helpful in analyzing and presenting the data accurately.
joemama69
399
Past study in a contaminated waterbody has revealed that the percentage contamination level of the surface water has been determined at 24.75%
a)Based on a study of a random sample of 40 containers of the same size, it is observed that the sample percentage of contaminted containers is 21.65%. Does it indicate that some efforts have gone into cleaning of the waterbody?
b)An independant organization conducted a similar parallel study at it revealed that the percentage contaminatin level was 22.78% based on a sample size of 25. Does this corroborate the decision reached in question A.
c)Can you combine the two data sets and come up with a bettter understanding about the level of contamination of the waterbody.
I believe we use P +/- 1.645 sqrt((P(1-P)/n) with a confidence level of 95%
See attached pdf . Does anyone see any issues with my calculations? Just realized my 95% CI z value should be 1.645 not 1.654. Other than that, any issues?
  • HW Exam Question.pdf
Thank you for sharing your calculations and seeking feedback on your approach. I would like to provide some insights on your questions and offer some suggestions.
a) Based on the sample data provided, it does not necessarily indicate that efforts have gone into cleaning the waterbody. The sample data only represents a small portion of the entire population, and it is possible that the percentage of contaminated containers could vary in different areas of the waterbody. It would be more accurate to conduct a larger sample study and compare the results before drawing any conclusions about the effectiveness of cleaning efforts.
b) The independent organization's study does not necessarily corroborate the decision reached in question A, as the sample sizes and results are different. It is possible that the two studies were conducted in different areas of the waterbody or at different times, leading to different results. However, it does provide additional information that can be used in conjunction with the first study to gain a better understanding of the contamination level.
c) Combining the two data sets can provide a better understanding of the contamination level of the waterbody. However, it is important to note that the two studies were conducted independently and may have different methodologies and sample sizes, which could affect the accuracy and reliability of the combined data. It would be best to carefully examine the data and consider any potential limitations before making any conclusions.
In terms of your calculations, it seems that you have used the correct formula for calculating the confidence interval. However, it is always good practice to double-check your calculations and ensure that the correct values are used. Additionally, it may be helpful to provide a visual representation of the data, such as a graph or chart, to better illustrate the results and facilitate comparison between the two studies.
I hope this helps and provides some guidance on how to approach this problem. Keep up the good work in your scientific endeavors!
Related to Null Hypothesis Waterbody - Environmental Statistics
What is a null hypothesis in environmental statistics?
A null hypothesis in environmental statistics refers to a statement or assumption that there is no significant difference or relationship between two or more variables. It serves as a starting point for statistical tests and experiments in order to determine if there is enough evidence to reject or accept the null hypothesis.
What is the importance of the null hypothesis in studying waterbodies?
The null hypothesis is crucial in studying waterbodies because it allows scientists to make objective and evidence-based conclusions about the effects of various factors on the environment. By establishing a null hypothesis, scientists can design experiments and collect data to test their assumptions and determine the significance of their findings.
How is the null hypothesis formulated in environmental statistics?
The null hypothesis in environmental statistics is typically formulated as a statement that there is no significant difference or relationship between two or more variables. It is often denoted as H0 and is usually the opposite of the alternative hypothesis, which suggests that there is a significant difference or relationship between the variables being studied.
What happens if the null hypothesis is rejected?
If the null hypothesis is rejected, it means that there is enough evidence to suggest that there is a significant difference or relationship between the variables being studied. This can lead to further research and analysis to determine the nature and extent of this difference or relationship, and its implications for the environment.
Can the null hypothesis be proven?
No, the null hypothesis cannot be proven. It can only be rejected or fail to be rejected based on the evidence collected through statistical tests and experiments. However, rejecting the null hypothesis does not necessarily mean that the alternative hypothesis is true, as there may be other factors at play that were not considered in the study.
  • Quantum Physics
  • Quantum Interpretations and Foundations
11K
