MHB Null Space of A: Find Rank & Dim.
karush
MHB
Let
$$\left[\begin{array}{rrrrrrr}
1 & 0 & -1 & 0 & 1 & 0 & 3\\
0 & 1 & 0 & 0 & 1 & 0 & 1\\
0 & 0 & 0 & 1 & 4 & 0 & 2\\
0 & 0 & 0 & 0 & 0 & 1 & 3
\end{array}\right]$$
Find a basis for the null space of A, the dimension of the null space of A, and the rank of A.ok following an book example I did this $Ax=b$
$$\left[ \begin{array}{ccccccc}
1 & 0 & -1 & 0 & 1 & 0 & 3 \\
0 & 1 & 0 & 0 & 1 & 0 & 1 \\
0 & 0 & 0 & 1 & 4 & 0 & 2 \\
\end{array} \right]
\left[ \begin{array}{c} x_{1} \\ x_{2} \\ x_{3} \\ x_{4} \\ x_{5} \\ x_{6} \\ x_{7}
\end{array} \right]
=\left[ \begin{array}{c} 0 \\ 0 \\ 0 \\ 0
\end{array} \right]$$
which would result in
$$\begin{array}{rrrrrrr}
x_1 & &-x_3 & &x_5 & &3x_7=0 \\
&x_2 & & &x_5 & &x_7 =0\\
& & & x_4 & 4x_5 & &2x_7=0 \\
& & & & & x_6 &3x_7=0
\end{array}$$ hopefully so far !
It is clear (by inspection, working from the last equation upwards) that you can let $x_7,x_5,x_1$ be arbitrary, then $x_2,x_3,x_4,x_6$ can be expressed in terms of them as:
$$x_6\ =\ -3x_7 \\ x_4\ =\ -4x_5-2x_7 \\ x_2\ =\ -x_5-x_7 \\ x_3\ =\ x_1+x_5+3x_7.$$
Hence:
$$\begin{pmatrix} x_1 \\ x_2 \\ x_3 \\ x_4 \\ x_5 \\ x_6 \\ x_7\end{pmatrix}\ =\ x_1\underbrace{\begin{pmatrix} 1 \\ 0 \\ 1 \\ 0 \\ 0 \\ 0 \\ 0\end{pmatrix}}_{\mathbf v_1} + x_5\underbrace{\begin{pmatrix} 0 \\ -1 \\ 1 \\ -4 \\ 1 \\ 0 \\ 0\end{pmatrix}}_{\mathbf v_2} + x_7\underbrace{\begin{pmatrix} 0 \\ -1 \\ 3 \\ -2 \\ 0 \\ -3 \\ 1\end{pmatrix}}_{\mathbf v_3}.$$
Verify that $\mathbf v_1,\mathbf v_2,\mathbf v_3$ are linearly independent and thus form a basis for the nullspace of $A$; hence $A$ has nullity $3$. The rank of $A$ can then be found from the formula $r(A) = \dim(A)-n(A)$.
You have 4 equations in 7 unknowns so the null space is 7- 4= 3 dimensional. You will need 3 basis vectors.
Ok that was very helpful
Not sure if I would know the linear independence of these
You prove those vectors are independent using the definitions of "independent" or "dependent".
Suppose the three vectors given by Olinguito were NOT independent. Then there would exist numbers, a, b, and c, not all zero, such that
a\begin{pmatrix}1 \\ 0 \\ 1 \\ 0 \\ 0 \\ 0 \\ 0\end{pmatrix}+b\begin{pmatrix}0 \\ -1 \\ 1 \\ -4 \\ 1 \\ 0 \\ 0 \end{pmatrix}+c\begin{pmatrix} 0 \\ -1 \\ 3 \\ -2 \\ 0 \\ -3 \\ 1 \end{pmatrix}=\begin{pmatrix}a \\ -b- c \\ a+ b+ 3c \\ -4b- 2c \\ b \\ -3c \\ c\end{pmatrix}= \begin{pmatrix} 0 \\ 0 \\ 0 \\ 0 \\ 0 \\ 0 \\ 0 \end{pmatrix}.
That gives 7 equations: a= 0, -b- c= 0, a+ b+ 3c= 0, -4b- 2c= 0, b= 0, -3c= 0, c= 0. Clearly the only a, b, and c that satisfy all 7 equations are a= b= c= 0. Therefore the three vectors are independent.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
