Number crunching machine on a small budget?
In summary, a single 5970 will give you nearly 5 Teraflops on 32-bit float. If you're looking for number crunching this will crunch numbers laughably faster than anything else that has been proposed, and at a fraction of the price.
Dunhausen
30
I'm looking for as much computational power as possible for maybe 2-3 grand.
This looks like a nice setup fit to the purpose, but I thought it would be good to ask and see what other people know or have been doing. (fyi I'm not really a hardware guy myself)
Glad for any input!
Computer science news on Phys.org
You should take a look at this set-up. It is a fairly cheap way of handling "number crunching" type situations without spending too much money. http://www.wired.com/wired/archive/8.12/beowulf.html"
3 grand will get you a lot of compute power. AMD's new 6 core chips can be had for $200 (it's called the 1055t, I think?), throw one of those on a $100 motherboard with 4GB of RAM (also about $100) for each node with the standard power supply/case/networking/storage stuff and you'll have a pretty good setup. A system using hex core chips should be cheaper and more efficient than one consisting of many dual core machines since there's much less duplication of hardware.
I've actually got the new Hex core and I am pretty happy with it.
I wouldn't use a 1050t or 1090t for number crunching when you got 2-3 grand to spend. Right now the best flop for the buck is the new g34 chipset from AMD. Nothing else is really going to come close unless you get a good deal some used stuff.
I start with a good dual socket G34 mobo;
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131643
with two of these;
http://www.newegg.com/Product/Product.aspx?Item=N82E16819105266&cm_re=magny-_-19-105-266-_-Product
Then buy a good PSU, some TB drives, and then spend the rest on some 1333 DIMMs.
Thanks everybody for the input! I didn't even know they made 8-core chips. :p
So far this is what I'm planning to order, which hopefully accounts for everything:
Component: ASUS KGPE-D16 Dual Socket G34 AMD SR5690 SSI EEB 3.61 Dual 8/12 Core AMD Opteron 6000 series Server Motherboard
Price: 439.99 + 10.18
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131643
Component: AMD Opteron 6128 Magny-Cours 2.0GHz 8 x 512KB L2 Cache 12MB L3 Cache Socket G34 115W 8-Core Server Processor
Price: 305.99 (x2)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819105266&cm_re=magny-_-19-105-266-_-Product
Component: Chenbro Case RM21706 (RM21706T-T) 2U DP with, 6 x Hotswap HDDs, SAS/SATA BP, Zippy Power Supply 510W (PS-P2G-6510P-T), Ideal For General Purpose Server - OEM
Price: 314.99
Link: http://www.newegg.com/Product/Produ...123142&cm_re=zippy_psu-_-11-123-142-_-Product
Component: Dynatron A5 60mm 2 Ball CPU Cooler
Price: 33.99+2.99 (x2)
Link: http://www.newegg.com/Product/Produ...cm_re=amd_g34_heatsink-_-35-114-112-_-Product
Component: Athena Power CA-SWH01BH8 Black Steel Pedestal Server Case 2 External 5.25" Drive Bays
Price: 269.99 + 27.91
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811192058
Component: ASUS DVD-E818A6T/BLK/B/G Black 18X SATA DVD-ROM Drive - Bulk
Price: 16.99 +6.98
Link: http://www.newegg.com/Product/Produ...135202&cm_re=dvd_drive-_-27-135-202-_-Product
Component: TRENDnet TEG-PCITXR 10/ 100/ 1000/ 2000Mbps PCI Copper Gigabit Network Adapter 1 x RJ45
Price: 13.99 + 2.99
Link: http://www.newegg.com/Product/Produ...139&cm_re=network_card-_-33-156-139-_-Product
Component: ASUS EN8400GS Silent/P/512M GeForce 8400 GS 512MB 64-bit DDR2 PCI Express 2.0 x16 HDCP Ready Video Card
Price: 24.99
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121360
Component: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Price: 59.99 (x2)
Link: http://www.newegg.com/Product/Produ...&cm_re=sata_hard_drive-_-22-136-319-_-Product
Component: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL8D-4GBRM
Price: 105.99 (x10)
Link: http://www.newegg.com/Product/Produ...3_desktop_memory_model-_-20-231-275-_-Product
Total: 2994.82
Why do you have two cases on your list? Also, the 510watt PSU included in that one case might be a little underpowered. I would recommend something in the 600+watt region which will also give you a bit of room for growing.
I would get something like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16817255056
A single 5970 will give you nearly 5 Teraflops on 32-bit float. If you're looking for number crunching this will crunch numbers laughably faster than anything else that has been proposed, and at a fraction of the price.
It does require knowledge in GPU programming paradigms. That's knowledge you will want to pick up sooner or later in any case.
http://www.newegg.com/Product/Produc...82E16817255056
Oh, yes, that was a mistake! Thank you!
Well, let's say GPU programming is on my to do list, but it may be a while before I get to it. However, that is some pretty impressive output from the 5970. Maybe it would be worth getting one upfront as a bit of hovering encouragement to learn CUDA. :p
Pattonias said:
Have you considered renting time on a super-computer?
This would provide way more data for the amount of money that you are wanting to invest.
Here is an example company.
I'll be doing that when necessary, this will just makes it necessary a little less, and there's quite a few advantages besides $/FLOP to having a machine on hand. It's also one of those things where you have a budget to buy some hardware, so hardware is what you buy!
Bear in mind that for CUDA you'd need an Nvidia graphics card (unlike the 5970 which is an ATI/AMD one, though there's always open CL, whih might be the better option for the future).
GPUs do give you a lot of power for the money but sometimes the PCI-E pipeline can significantly bottleneck computation time if using of card memory. So while the cost of the card(s) may be cheap, the cost of the mobo may not be.
FAQ: Number crunching machine on a small budget?
1. What is a "number crunching machine"?
A number crunching machine is a computer or device that is specifically designed to perform complex mathematical calculations or data analysis at high speeds. It is also known as a supercomputer or high-performance computing (HPC) system.
2. How can I build a number crunching machine on a small budget?
There are a few ways to build a number crunching machine on a small budget. Firstly, you can opt for refurbished or second-hand parts instead of buying brand new ones. You can also consider using open-source software and operating systems to save on licensing fees. Additionally, you can prioritize and invest in components that are crucial for number crunching, such as a powerful CPU and plenty of RAM, while saving on other components like a fancy graphics card.
3. What are the minimum requirements for a number crunching machine?
The minimum requirements for a number crunching machine may vary depending on the specific tasks and calculations you need it to perform. However, some important components to consider are a fast CPU with multiple cores, a high amount of RAM, and a reliable storage system, such as solid-state drives. It is also important to have a good cooling system to prevent overheating during intensive calculations.
4. Can I use a regular computer for number crunching?
While a regular computer can perform basic calculations and data analysis, it may not have the power and speed to handle more complex number crunching tasks. A dedicated number crunching machine is designed and optimized specifically for these types of tasks, making it more efficient and effective. However, if you have a powerful computer with high-end components, it may be possible to use it for some number crunching tasks.
5. Are there any alternatives to building a number crunching machine on a small budget?
Yes, there are some alternatives to building a number crunching machine on a small budget. One option is to use cloud computing services, which allow you to rent computing power and resources as needed for your specific tasks. This can be a more cost-effective solution for those who don't have the budget or resources to build their own number crunching machine. Another option is to collaborate with other researchers or organizations that may have access to a powerful number crunching machine.
