Number displayed on an electric scale when an object hits it
In summary, the scale reading is given by F = kx when the object hits it and x is the potential energy of the object at that moment.
ChessEnthusiast
115
We have an object, whose mass is accumulated in its center. The mass is m.
We let an object positioned at the height of h over the scale free fall.
Let R be the number that will be displayed on the scale right when the item hits it.
Find R(h).
2. The attempt at a solution
[tex]v_{terminal} = \sqrt{2gh} [/tex]
[tex]p = m \sqrt{2gh}[/tex]
[tex]R = \frac{F}{g}[/tex] where [tex]F = \frac{dp}{dt}[/tex]
Since the force the object will exert on the surface of the scale is the change in momentum over the change in time, how am I supposed to determine the time, during which the momentum was "transferred"?
You're certain you've transcribed the problem statement completely and correctly?
have you seen a fault?
To be honest if you, I also feel as if some information were lacking here. Anyway, can you understand the point of this problem? Have I explained it precisely enough?
The problem asks for the scale reading when the object first hits it. What is the scales spring deformation at that instant?
There will be hardly any deformation, because the scale is electric.
Point out to the "poser" of the problem that there's something "missing," and hope for the best.
What if we assumed that the scale will slightly deformate once the object hits it? Would it, then, be solvable?
There won't be any deformation even if the scale is like my old fashioned non trustworthy bathroom spring scale. Either info is missing or if you take the problem as written, the scale reading per F = kx. Is_______?
[tex]kx / g [/tex]
As others have noted, that does not strictly make sense. But from a practical point of view, what you would see is a large value displayed almost immediately. So I would interpret it as the maximum value displayed.
[tex]kx / g [/tex]
That is the mass shown when the spring compression is x, but you do not know what x is. See my preceding post.
[tex] m\sqrt{2gh} / dt = kx [/tex]
[tex]x(t) = \frac{m}{t} k\sqrt{2gh}[/tex]
[tex]R = \lim_{t \to 0} \frac{x(t)}{g}[/tex]
Is it the potential solution?
I gather electric scales give max readings at the moment of impact? I think mine reads 888 for some reason. Anyway, imagine it is an old fashioned scale that reads 0 at no load , like a grocery scale for weighing bananas. F= kx and at the very instant of impact, x is _____ so F is?
[tex]x = \sqrt{\frac{2mgh}{k}}[/tex]
And hence
[tex] F = \sqrt{2mghk} [/tex]
I think this should work.
And hence
This cannot be exactly right since it does not tend to 2mg as h tends to zero. In the conservation of energy equation, you need to take into account the total distance which the mass descends (it's a bit more than h). And the final answer should be in terms of the indicated mass, not in terms of the force.
Related to Number displayed on an electric scale when an object hits it
1. What does the number displayed on an electric scale represent?
The number displayed on an electric scale represents the weight of an object placed on the scale. It is typically measured in units of pounds (lb) or kilograms (kg).
2. How does an electric scale measure the weight of an object?
An electric scale works by using a strain gauge, which measures the amount of force exerted on the scale's surface. This information is then converted into a numerical value and displayed on the scale's screen.
3. Why does the number on an electric scale fluctuate?
The number on an electric scale may fluctuate due to slight movements or changes in weight distribution of the object on the scale. It can also be affected by external factors such as air currents or vibrations.
4. Can an electric scale accurately measure the weight of all objects?
No, an electric scale is designed to measure the weight of objects within a certain weight range. If an object is too heavy or too light for the scale, it may not provide an accurate measurement.
5. How can I ensure the accuracy of the number displayed on an electric scale?
To ensure the accuracy of the number displayed on an electric scale, it is important to properly calibrate the scale before use. This involves placing a known weight on the scale and adjusting it to match the weight. Additionally, the scale should be placed on a flat and stable surface to avoid any errors in measurement.
