Number of atoms in FCC gold cube with only the radius given
In summary, we are trying to find the ratio Ns/Nv as a function of L (gold cube side) and a parameter of FCC lattice, given that the radius of a gold atom sphere is 144.2 pm and the gold is packed in an FCC manner. To determine this ratio, we first calculate the number of atoms per unit, which is 4L^3/a^3. Then, to find the number of surface atoms, we need to consider the number of inner cells and surface sheets, taking into account the shared atoms at the corners and edges. After counting all the surface atoms, we can determine the ratio Ns/Nv.
nour halawani
number of atoms in FCC gold cube with only the radius given!
1)it is given that the radius of a gold atom sphere is 144.2 pm, gold is packed in an FCC manner
Give the ratio Ns/Nv as a function of L (gold cube side) and a parameter
of FCC latice, knowing that Ns is the number of surface atoms and Nv is the number of atoms per volume.
2) and 3)
what i am thinking is:
in a unit cell we have 1/8 x 8 corner atoms = 1 atom and in the center of each phase we have 1/2 x 6 = 3 then the total number of atoms will be 4
atoms per unit = 4
volume of the cube is L^3 and volume of the unit is a^3 so if we want to know how many units are there in this cube we can divide the volume of the cube over the volume of the unit cell and we will have L^3/a^3
and if we multiply them by 4 which is the number of atoms per unit we will have the number of atoms in a cubic volume Nv= 4L^3/a^3
now talking about the surface is the thing confusing me
counting the atoms in unit cell is it 2 coming from 4 corners shared by 4 cells which is 1/4 x 4 and 1 center atom and by this we will have 2 atoms or my thinking is not reasonable?
won't i have an answer :(
2) and 3)
atoms per unit = 4
Correct so far...
You do it well, and it will work well for large number of cells, but it is worth to count the atoms more carefully.
The gold cube has a sheet of surface cells on each side, 6 altogether. So the number of the inner cells is (L/a-2)^3.
Try to draw a cube of a few units. The cube in the picture is of 8x8x8 units, with 6x6x6 inner cells.
On one surface sheet, there are (L/a-2)^2 inner squares, which share the atoms at the corners with 3 other squares, and have their own atoms in the middle.
You have 12 edges of the gold cube. From each edge, (L/a-2) units are inner ones. The units have two unshared atoms at the centre of the outer sides, and common atoms at the outer corners.
There are eight corner cells with unshared atoms on the outer sides and corner.
Count all surface atoms, and take care so you do not count any of them twice.
ehild
Related to Number of atoms in FCC gold cube with only the radius given
1. How do you calculate the number of atoms in an FCC gold cube with only the radius given?
To calculate the number of atoms in an FCC (face-centered cubic) gold cube, you can use the formula: N = (4/3) * π * r3 * ρ * NA / M, where N is the number of atoms, r is the radius of the cube, ρ is the density of gold, NA is Avogadro's number, and M is the atomic mass of gold.
2. What is the radius of an FCC gold cube with a known number of atoms?
To find the radius of an FCC gold cube with a known number of atoms, you can rearrange the formula in question 1 to solve for r. The formula would then be: r = [(3N * M) / (4π * ρ * NA)]1/3, where r is the radius, N is the number of atoms, ρ is the density of gold, NA is Avogadro's number, and M is the atomic mass of gold.
3. Can the number of atoms in an FCC gold cube change if the radius changes?
Yes, the number of atoms in an FCC gold cube will change if the radius changes. This is because the number of atoms is directly proportional to the volume of the cube, which is determined by the radius. As the radius increases, the volume and number of atoms will also increase, and vice versa.
4. What is the density of gold in an FCC cube with a given number of atoms?
The density of gold in an FCC cube with a given number of atoms can be calculated by using the formula: ρ = (M * NA) / (N * V), where ρ is the density, M is the atomic mass of gold, NA is Avogadro's number, N is the number of atoms, and V is the volume of the cube.
5. How does the number of atoms in an FCC gold cube compare to other crystal structures?
The number of atoms in an FCC gold cube is the highest among the common crystal structures. This is because the FCC structure has the most efficient packing of atoms, with each atom having 12 nearest neighbors. In comparison, the body-centered cubic (BCC) structure has 8 nearest neighbors per atom, and the simple cubic (SC) structure has 6 nearest neighbors per atom. Therefore, the number of atoms in an FCC gold cube will be greater than the number of atoms in a BCC or SC gold cube with the same radius.
  • Atomic and Condensed Matter
  • Quantum Physics
