Number of atoms trapped in an atom trap
In summary, the problem involves calculating the number of trapped atoms in a point-like volume based on the light intensity measured by a sensor 25 cm away from the atoms. Each atom emits 1.0 x 10^6 photons of wavelength 780 nm per second, and the sensor measures an intensity of 1.6 nW. Assuming equal probability of photon emission in all directions, the total number of trapped atoms can be calculated by finding the ratio of the sensor area to the total surface area of a sphere with radius 25 cm, and then using this ratio to determine the total number of photons emitted by the source per second. Finally, dividing this number by the number of photons emitted per atom will give the total number of atoms in
stigg
31
a group of atoms are confined in a point like volume in a laser based atom trap, the laser light causes each atom to emit 1.0 x 10^6 photons of wavelength 780 nm every second. the sensor has area of 1 cubic centimeter and measure the light intensity emanating from the trap to be 1.6 nW when placed 25 cm away from the trapped atoms. assuming each atom emits photons with equal probability in all directions, determine the number of trapped atoms.
i honestly don't know where to begin with this problem, any guidance would be greatly appreciated, thanks
Calculate the power emitted by a single atom. You have the number of photons it emits per second as well as their frequency so you can calculate the total energy emitted in 1 s, and thus get the power emitted.
The energy emitted by a single atom will be distributed homogeneously radially from it. Since your censor is 1 cm³ and inside an imaginary sphere of radius 25 cm, you can calculate how much % of the light (and hence power) coming from a single atom is received.
Can you figure out how to continue?
i found the frequency using f=v/[itex]\lambda[/itex] and then the power using hf emitted by each photon then multiyply that by the number of photons released per second, is this correct?
I'm not sure what you mean. The "hf" term is energy, not power. With the "hf" term you get the energy of a single photon. A single atom emits 10^6 of these photons, per second.
ah yes youre right my mistake, so i used E=hf and mulitpled it by 10^6 photons per second which would then in turn be equal to the power, correct?
Yes, exactly. Let P be this power. It will be distributed uniformly radially from the source. For instance, at 1 m away from the source, the power emitted by a single atom will be distributed over a surface of [itex]4 \pi[/itex]. At a distance r, [itex]4 \pi r ^2[/itex]. In the problem you are given a distance and the volume of the sensor. Do you have an idea how to calculate the percentage of emitted photons received in the sensor?
first find the total intensity over the surface area of the sphere with radius 25cm and then find what fraction of that the sensor area is?
Yes.
i have the ratio of the sensor area to the total sphere area, however how do i use that to find the emmitted photons in the sensor
Ok good.
This ratio is the percentage of the emitted photons that are received by the sensor, for all atoms. In the problem statement they give the information that the intensity in the sensor is 1.6 nW. You can determine the number of photons the sensor receives per second.
Let's suppose (unrealistically) that the sensor receives 100 photons per second. And that you calculated that a single atom emitts 30 photons per second. Say you calculated the ratio we're talking about as being 1%. It means that the total source (or all atoms together) emitts 100 times more photons than then ones your sensor receives. Thus, in total 10,000 photons are emitted from the source per second. There's a very small last step, let's see if you can figure it out. :)
i divided the number of photons hitting the sensor per second by the ratio we talked about to receive the total number of photons released from the source per second i then divided this by the number emitted per atom to find the number of atoms in the source. does this sound correct?
I think so :) Post your numbers just in case the result is strange.
i calculated 1.95 x 10^12 atoms in the source, would you like my other numbers as well
No need, that looks "possible" at first glance.
I'm glad you've solved your problem.
sounds good, thanks a bunch for the help glad i came here it was very useful!
You're welcome and feel free to use this forum (as much as I do :biggrin:).
FAQ: Number of atoms trapped in an atom trap
1. How are atoms trapped in an atom trap?
Atoms are trapped in an atom trap using lasers and magnetic fields. The lasers create an optical potential that traps the atoms within the trap, while the magnetic fields help to confine the atoms within the laser beams.
2. What is the purpose of trapping atoms in an atom trap?
The purpose of trapping atoms in an atom trap is to study their behavior and properties in a controlled environment. This can help scientists better understand the fundamental laws of physics and could also have practical applications in areas such as quantum computing and precision measurements.
3. How many atoms can be trapped in an atom trap?
The number of atoms that can be trapped in an atom trap depends on the type and design of the trap. Some traps can hold a few hundred atoms, while others can hold millions. However, the number of atoms trapped is usually in the range of thousands to tens of thousands.
4. How long can atoms be trapped in an atom trap?
The length of time that atoms can be trapped in an atom trap also varies depending on the type of trap. Some traps can hold atoms for a few milliseconds, while others can trap them for several seconds or even longer. However, the atoms are typically released from the trap after a certain amount of time to prevent them from losing their quantum properties.
5. What are the benefits of trapping atoms in an atom trap?
Trapping atoms in an atom trap allows for precise control and manipulation of the atoms, making it useful for experiments and potential applications in technology. It also allows for the study of individual atoms and their interactions, which can provide insights into the behavior of larger systems and materials.
