Master1022
- 611
- 117
- Homework Statement
- If we have a 6-sided die (it is a fair die), how many throws would we expect to make before we see a repeated number?
- Relevant Equations
- Probability
Hi,
I found a similar problem online, but there wasn't any solution. The question actually had a larger number of sides (e.g. 50 or 100, etc.), but I thought the underlying solution method should be the same for any arbitrary ##n##-sided die.
Question:
Attempt:
I have been thinking about this problem for a while, and am very stuck on how to proceed. I did write a Python script to simulate this game for different ##n##, and the graph aligned with intuition (larger ##n## required more throws until repetition). I remember reading that this problem was similar to the birthday paradox conceptually, however I haven't been able to use that to solve the problem.
If I follow that birthday paradox line of reasoning, I suppose I could do:
[tex] P(\text{repetition on 5th throw}) = 1 \times \frac{5}{6} \times \frac{4}{6} \times \frac{3}{6} \times \frac{4}{6} = \frac{(6)! \cdot 4}{(6-4)! \cdot 6^5} [/tex]
Thus this could be generalized to the probability of a repetition on the ##k##-th throw:
[tex] P(\text{repetition on k-th throw for n sided die}) = \frac{(n)! \times (k-1)}{(n-(k-1))! \cdot n^k} [/tex]
Is the above correct? I am not sure I am fully convinced by the abiThis question was an interview question, so how could one find the expected number without a calculator - are there tricks or approximations?
Any help would be greatly appreciated.
Question:
Attempt:
