Number of functions from a to b where {123} is in the range of (f)
In summary, there are n elements in A and B is a set containing 0, 1, 2, and 3. The range of f must include the set {1, 2, 3}. To choose the 3 numbers in the range, there are n*(n-1)*(n-2) possibilities. For the remaining elements, there should be 4n-3. Therefore, there are a total of n*(n-1)*(n-2) * 4n-3 different functions. However, this method may result in some functions being counted twice, so inclusion-exclusion should be used to determine the correct number of functions.
Dank2
213
A has n elements.
B={0,1,2,3}
{1,2,3}⊆range(f)
So in each function we must choose those 3 numbers in the range.
So let's first choose all the diffrent possiblites to choose those 3:
n*(n-1)*(n-2)
now for the remaining elemnts, we should have 4n-3
So totally we should have n*(n-1)*(n-2) * 4n-3 diffrent functions.
You can't separate them like that. You would e.g. count (1,2,3,3) twice, once with the first 3 "chosen" and once with the second one.
You can use inclusion-exclusion: How many functions are there in total? How many without 3? How many without 2? Without 1? How many did you subtract twice now?
Related to Number of functions from a to b where {123} is in the range of (f)
What is the definition of a function?
A function is a mathematical relationship between two sets of numbers, where each input from one set (the domain) corresponds to exactly one output from the other set (the range).
What is the range of a function?
The range of a function is the set of all possible output values that can be generated by the function for each input value in the domain.
How do you determine if {123} is in the range of a function?
To determine if {123} is in the range of a function, you can plug in the values of {1, 2, 3} into the function and see if it produces an output. If it does, then {123} is in the range of the function.
What is the significance of {123} being in the range of a function?
If {123} is in the range of a function, it means that the function can generate the number 123 as an output. This can provide insight into the behavior and properties of the function.
How does the number of functions from a to b where {123} is in the range of (f) vary?
The number of functions from a to b where {123} is in the range of (f) can vary depending on the specific values of a and b, as well as the properties and restrictions of the function. Generally, there can be a large number of possible functions in this scenario.
