Number of moles of polymer formed
  • Chemistry
  • Thread starter Janiceleong26
  • Tags
    Moles Polymer
In summary, Januce asks how many moles of a polymer there are if it's one molecule. Two and three are correct answers, but Januce wonders if this is a case of "when you've got the answer it's not finished." Option 2 is also possible.
Janiceleong26
276
  • Homework Statement
2. The attempt at a solution
I chose no. 1 only, but the answer is 2&3, I can't seem to see how 10^-6 came about. And for C, I'm not clear how it came about too.. Is it because 1 mole consists of 6x10^23 atoms, so no. of moles of the polymer is 1/(6x10^23) ? And why is 1 mole wrong?
Imagine you have two A. Can you make two pairs (AA) of the two A you have?
Choose a molecular weight for the monomer (say 100 g/mol) and play with the numbers.
Likes Janiceleong26
No..
Janiceleong26 said:
No..
Do you see how it is related to the problem? And to the 1st answer?
Likes Janiceleong26
What would happen if the all the monomer reacted with itself to form one long gigantic molecule of enormous molecular weight. How many moles does 1 molecule represent?
Likes Janiceleong26
Erm.. Is it like for one polymer to form, we need at least two monomers? So it should be at least two moles till infinite? What about option 2?
Erm, 1/ (no. of monomers joined) ?
So, how many moles of the product you will get?
Now try to answer Chester's question. Basically he is asking - 1 molecule, how many moles is it?
I'm not sure.. 1/(no. of moles of monomers) ?
1 molecule of anything - how many moles of that substance? Don't think about monomers and polymers for a while, this is a simple, basic question about moles as such.
1/(6.02x10^23)
OK, so, if everything reacted, you will get a single polymer molecule, or 1/6.02×1023 moles of product, yes?
Now, if the reaction were exactly 2A→AA, and you started with 1 mole of A, how many moles of the AA polymer would be produced?
1/2 mole of AA
So, if there was a simplest reaction, there is no way 1 mole of polymer could be produced, right? But depending on the product everything between 1/2 mole of 1/6.02×1023 is possible, isn't it?
Yup true. Thanks for the help
But what about option2? :biggrin:
Reread what I wrote, the answer is there. Start with the word "everything".
OHHH... I see I see :woot:
Between 0.5 mole to 1/(6.02x10^23) mole , 10^-6 is within the range
Thanks !
OK 2 and 3 are both correct answers. But I think this is a case of "when you've got the answer it's not finished."
2 is a typical possible figure I think for a polymer.
For 3 I think the operative word in the question is theoretically.
Would you care to work out how long is 1 mole if it's one molecule?
I think macromolecules don't come longer than DNA. One fairly avverage human chromosome has 220X106 base pairs in a DNA molecule thought to be continuous. In the ordinary double-helical structure contains about 10 basepairs per turn and each turn is about 0.34 nm long. It normally folds back on itself, but if it were extended in a line now far would a mole go, would you care to work out and tell us?
epenguin said:
...if it were extended in a line now far would a mole go...
Might it be on the order of light-days?
Hm, question never said polymer can't undergo crosslinking. I have no problems assuming a huge object made of a crosslinked polymer is actually a single molecule.
Don't guess, this is trivial to estimate.
That wasn't a guess.
I hoped Januce could discover and surprise herself. :oldsmile:
And pick up a useful habit.
Sorry for the really late reply as i was busy with exams.
I'm not too sure if my working is right.. but this is what I did:
1 basepair has a length of 0.034nm
1 molecule of DNA has 220x10^6 base pairs, in 1 mol there would be 220x10^6 x 6.02 x10^23 =1.324 x 10^32 base pairs.
Length of 1 mol of DNA would be 1.324 x 10^32 x 0.034 nm = 4.50 x 10^21 m
I'm sorry, I am not too sure what you mean by how long is 1 mole if it's 1 molecule.. I thought 1 mole has 6.02 x 10^23 molecules?
That is truly astrononomical. What I had actually meant was one mole of nucleotide or of basepairs.
When I worked that out (a single human chromosome unwound if it could be straightened but still the double-helical structure) this was already fairly astronomical, a large fraction of a light year. 1mole of DNA as you have calculated is a large mass and a huger length of zillions of light years.
The single human chromosome unwound if it could be straightened in this way is reckoned to be a few centimeters. The chromosome you see photos of in your genetics texts is of order, if I remember, a micron. Very condensed. (Though remember those pictures where they are seen and counted etc. are in a cell-cycle phase where they are most highly condensed.)
Related to Number of moles of polymer formed
1. How is the number of moles of polymer formed calculated?
The number of moles of polymer formed can be calculated by dividing the mass of the polymer by its molar mass. This can be determined by multiplying the number of atoms of each element in the polymer by their respective atomic masses and adding them together.
2. What is the significance of knowing the number of moles of polymer formed?
The number of moles of polymer formed is important in determining the yield of a reaction and the amount of reactants needed. It also allows for accurate calculations of other properties, such as concentration and volume.
3. Can the number of moles of polymer formed be affected by reaction conditions?
Yes, the number of moles of polymer formed can be influenced by factors such as temperature, pressure, and the presence of catalysts. These conditions can alter the rate and extent of the polymerization reaction, ultimately affecting the final yield.
4. How does the structure of the monomer affect the number of moles of polymer formed?
The structure of the monomer can impact the number of moles of polymer formed through its reactivity and the type of polymerization reaction taking place. Different monomers have varying degrees of reactivity, and some may form more or less polymer depending on the type of reaction used.
5. Is there a limit to the number of moles of polymer that can be formed?
Yes, there is a limit to the number of moles of polymer that can be formed in a given reaction. This is determined by the amount of monomer and the reaction conditions. Once all the monomer is consumed, the reaction will stop, and the number of moles of polymer formed will reach its maximum yield.
