Number of pairs of integers satisfying this sum
  • Thread starter timetraveller123
  • Tags
    Integers Sum
In summary, the equation can also be written as a( \sqrt b + \frac 1 {\sqrt b})^2 = k^2 meaning that a = n2 for some integer n and \sqrt b + \frac 1 {\sqrt b} = l for some integer l defining j = l2 b2 + b (2 - j ) + 1 = 0 taking discriminant it must be more than zero hence j≤4 but for j < 5, the opposite is true.why do you have to expand it i just didΔ = (2 - j)2 -
timetraveller123
621
45
determine the number of pairs of integers (a,b) 1≤b<a<200 such that the sum
(a+b) + ( a-b) + ab + \frac a b\
is the square of an integer
i have the solution to the problem this was the given solution
the given equation is equivalent to
\frac {a*(b+1)^2} b\\
hence
\frac a b = n^2\
hence a = bn2 ≤ 200
we must have b≥ 1 and n ≥2 where b and n are integers
thus the number of pairs is given by
floor(200/1^2) + floor (200/2^2) ... floor (200/14^2) ## = 112 pairs
this is the given solution i don't quite understand the last part are they using b = 1
i did another method but i am not sure what is wrong someone point the mistake to me thanks it is below
[/B]
j≤4
hence
l ≤ ±2
only j = 4 gets a real b
hence b = 1 so i got b = 1 is the only value for b is it correct
next
we have 4a = k2
4≤ k2 ≤ 800
the number of squares between the range is definitely not 112 so what am i doing wrong?
vishnu 73 said:
##a( \sqrt b + \frac 1 {\sqrt b}) = k^2##
##a( \sqrt b + \frac 1 {\sqrt b}) \ne (a+b) + ( a-b) + ab + \frac a b##
For b = 1 and a = 4.
i am sorry that is not the correct equation i forgot the square i edited it now
j≤4
##\Delta = (2-j)^2 - 4 = 4 + j^2 - 4j - 4 = j^2 - 4j ##
But for j < 5, the opposite is true.
Δ = (2 - j)2 - 4≥0
2-j ≥ ±2
j cannot be zero
j = 1,2 of which only j = 2 gives a real b
then b = 1
edit:
my method is wrong sorry about that
so using your method
j<0 or j>4
so b≥1
then how do i do we have a = n2
oh wait my method is completely off and only just proved the already given statement that b>0
so my method has been completely wrong
i understand the given solution to the end but what are they doing with the floor function
I don't think
##\displaystyle \lfloor 200/1^2 \rfloor + \lfloor 200/2^2\rfloor+ ...+ \lfloor 200/14^2\rfloor##
equals 112 as ##\lfloor 200/1^2 \rfloor ## is 200. I think the given expression is 312.
Edit:-
I see what they did now,
##\displaystyle \lfloor 200/1^2 \rfloor + \lfloor 200/2^2\rfloor+ ...+ \lfloor 200/14^2\rfloor = 312##
but since ##a \ne b##, so they subtracted 200 from it.
no i am sorry once again ignore the first term only starts from 22
what exactly are they doing
are they just finding all the possible value of b by using floor(200/n2) where n goes from 2 to 14
but the condition is only that bn2 ≤ 200
then couldn't we also use floor(199/n2) why 200
You know ##a = bn^2##, so you need all ##b## that multiplied by some ##n^2## give some ##a## less than ##200##.
Here ##n^2## is constant.
Lets say ##mk = z## where k is some real number, then you know that ##mj = i < z## if ##j < k##.
Now if you want to find all ##(i,j)## such that ##i/j = m## then you just need to count the number of ##j## which is all +ve integers less than ##k##.
If we have ##g(m)## which gives the number of ##(i,j)## for a ##m##. Then we will define ##g## by ##\displaystyle g(m) = \begin{cases} \operatorname{floor}(z/m)\qquad \text{if z is not divisible by m} \\ z/m - 1\qquad \text{else} \end{cases}##.
If you take ##m = n^2## from ##2## to ##14##, ##j = b##, ##a= i## and ##z= 200## and apply the above logic you will get your answer.
On a side note, If I understand correctly then the given answer is a bit wrong since for ##n = 2##, floor(200/4) = 50, but for ##b = 50##, ##a= 200## which is not possible, so ##49## is correct number of pairs for ##n = 2## not ##50##.
Likes timetraveller123
The condition is ##bn^2 < 200## not ##bn^2 \le 200##, since ##a< 200## not ## a \le 200##.
Look at the first sentence of your question.
ya i agree there is something wrong with the solution you are right but now i am still trying to understand your solution now thanks for it
If you don't understand then you can ask me.
ya so this is my question thanks for being patient with me really appreciate it
so for n = 3 we had
floor(200/9) giving b =22 but why couldn't b have been 21
because 21 * 9 = 189 = a < 200 why not
it is the inequality that is giving me all the trouble
##(a+b) + ( a-b) + ab + \frac a b## is the square of an integer
##\frac {a*(b+1)^2} b##
Neither of these is an equation (no = sign) -- they are expressions. If two expressions have the same value, they are equal, not equivalent.
Likes SammyS
so for n = 3 we had
Yes it can be. It can be ##20, 19 ,... ##.
I never said ##b## can be less than the "floor value" rather than it can be all values less than the "floor value". We are not interested in the value rather than the number of values for ##b##. The number of b's is equal to "floor value" if ##200/n^2## is not a whole number.
omg it all makes sense now when you said the floor gives the number of b rather than b itself thanks a lot couldn't express how much it helped thanks once again a lot good luck with your career !
Likes Buffu
hence
\frac a b = n^2\
hence a = bn2 ≤ 200
[/B]
j≤4
hence
l ≤ ±2
next
we have 4a = k2
4≤ k2 ≤ 800
Using ##b = a/n^2## we have
(a+b) + ( a-b) + ab + \frac{a}{b} = \left(n + \frac{a}{n} \right)^2,
so ##n + a/n ## must be an integer. Thus, ##a## must be a multiple of ##n##. We can easily enough enumerate and count the possibilities for ##n=1##, ##n=2##, ##n=3, \ldots , n = 199##.
Related to Number of pairs of integers satisfying this sum
1. What is meant by "Number of pairs of integers" in this context?
"Number of pairs of integers" refers to the total count of pairs of whole numbers that can be added together to equal a given sum.
2. How do you determine the number of pairs of integers that satisfy a given sum?
The number of pairs of integers can be determined by using mathematical equations and techniques, such as algebra, to solve for all possible combinations of numbers that add up to the given sum.
3. Is there a specific formula or method for finding the number of pairs of integers that satisfy a sum?
Yes, there are various formulas and methods that can be used to find the number of pairs of integers, such as using the quadratic formula or creating a table of values to systematically solve for all possible combinations.
4. Can the number of pairs of integers change depending on the given sum?
Yes, the number of pairs of integers can vary depending on the given sum. For example, a smaller sum may have fewer pairs of integers that satisfy it compared to a larger sum.
5. Are there any restrictions or limitations on the integers in a pair?
Typically, the integers in a pair are limited to whole numbers, but this may depend on the specific problem and context. Some problems may also have additional restrictions, such as only using positive integers or a specific range of numbers.
