Number of Partitions of n into j Parts not Exceeding m?
  • MHB
  • Thread starter poissonspot
  • Tags
    Partition
In summary: What I am hoping to find is the number of j-tuples of positive integers that are non increasing so that a0+a1+...+aj=n and ai is less than or equal to m.
poissonspot
40
Remember that the number of partitions of n into parts not exceeding m is equal to the number of partitions of n into m or fewer parts? Does anyone know much about the number of partitions of n into m parts not exceeding m?
Thanks!
Edit: Or more generally, the number of partitions of n into j parts not exceeding m?
Thanks again,
Thanks!
Thanks again,
All right, so after trying to make sense of your post, I've decided that there are the following distinct questions to be answered here:
1: In how many ways can one partition $n$ objects into groups of less than $m$
2: In how many ways can one partition $n$ objects into $m$ or fewer groups
3: In how many ways can one partition $n$ objects into $j$ parts not exceeding $m$
Please correct me if you meant something else.
Hey, I'm just talking about integer partitions, but I'm sorry about the lack of clarity. I think it's well known that the number of partitions of an integer n w/ largest part m is equal to the number of partitions of n with m parts a statement equivalent to the first line "Remember".
However, I'm really interested in the question of how many integer partitions of n with j parts have parts not exceeding m.
Does that clarify things a little?
I realize you mean for $m,n,j$ to be integers. It's still a tough problem.
After looking carefully, the link wasn't as related as I thought, so sorry about that.
Some things I figured out that might help: you can add up the multinomial coefficients
\binom{n}{k_1,k_2,...,k_m}
Over all choices of $k_j$ such that $0≤k_j≤n$, not counting repeating combinations of $k_j$, and $\sum_{j=1}^m k_j=n$, which I haven't found a way to simplify.
Or, if we're looking at the wider version of the problem where we have labeled parts $A_1,A_2,...,A_m$, then the number of ways you can distribute the $n$ objects to the $m$ sets (including potentially empty $A_j$s) is simply $m^n$.
Thanks again.
Partition (number theory) - Wikipedia, the free encyclopedia
FAQ: Number of Partitions of n into j Parts not Exceeding m?
What is the formula for calculating the number of partitions of n into j parts not exceeding m?
The formula for calculating the number of partitions of n into j parts not exceeding m is given by the following recurrence relation: P(n,j,m) = P(n-1,j,m) + P(n,m-1,j-1) where P(n,j,m) represents the number of partitions of n into j parts not exceeding m.
How is the number of partitions of n into j parts not exceeding m related to the number of partitions of n into j parts?
The number of partitions of n into j parts not exceeding m is a subset of the number of partitions of n into j parts. This means that the total number of partitions of n into j parts not exceeding m will always be less than or equal to the total number of partitions of n into j parts.
Can the number of partitions of n into j parts not exceeding m be negative?
No, the number of partitions of n into j parts not exceeding m cannot be negative. It is always a positive integer, including 0.
Is there a limit to the value of m in the formula for calculating the number of partitions of n into j parts not exceeding m?
Yes, the value of m cannot exceed the value of n. This is because each partition is made up of positive integers, and if m is greater than n, it would not be possible to create a partition.
Can the number of partitions of n into j parts not exceeding m be calculated using other methods?
Yes, there are other methods for calculating the number of partitions of n into j parts not exceeding m, such as using generating functions or using Ferrers diagrams. However, the formula given by the recurrence relation is the most common and efficient method.
