MHB Number of real roots of a quartic
  • Thread starter Thread starter CaptainBlack
    Roots
The polynomial p(x) = x^4 - x^3 - 1 has exactly two real roots, one positive and one negative, as determined by Descartes' rule of signs. The analysis of the related polynomial q(x) = x^4 - x^3 reveals a root of order 3 at x=0 and a root of order 1 at x=1, with a minimum value of -27/256 at x=3/4. This indicates that for values of a less than -27/256, the quartic equation has two real roots, while for a equal to -27/256, it has one double root, and for a greater than -27/256, it has no real roots. Thus, the effective number of real roots can be confirmed through both Descartes' rule and the examination of q(x). The discussion concludes that the polynomial indeed has two real roots.
CaptainBlack
rayman's question from another place:
Could someone help me with this problem, I have no idea how to start with it
How many real roots does this polynomial have p(x)=x^4-x^3-1?
Clearly state the argument that explains the number of real roots.Thank you for any help
Descartes rule of signs tells you this has exactly 1 positive root, and exactly 1 negative root, so it has two real roots.
CB
Mathematics news on Phys.org
The Descartes rule establishes the maximum number of positive/negative real roots that a polynomial can have but it gives no information about the effective number of the real roots of a polynomial. In our case is $\displaystyle p(x)= x^{4}-x^{3} -1$ and, in my opinion, the number of its real root can be found considering the polynomial $\displaystyle q(x)= x^{4}-x^{3}$. It is easy enough to see that $q(x)$ has a root of order 3 in x=0 and a root of order 1 in x=1. Furthermore q(x) has a minimum in $x=\frac{3}{4}$ and here is $q(x)=- \frac{27}{256}$. Now if we consider the quartic equation $\displaystyle q(x)+a=0$, on the basis of consideration we have just done, it is easy to find that the quartic equation has two real roots for $a<\frac{27}{256}$, one real root of order 2 for $a=\frac{27}{256}$ and no real roots for $a>\frac{27}{256}$...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
In this case Descartes rule of signs does tell us exactly how many real roots we have.
The number of positive roots is equal to the number of changes of signs of the coefficients less a multiple of 2. In this case the number of sign changes is 1, and as there is no multiple of 2 other than 0 which leaves the number of roots non-negative there is exactly one positive real root. The same argument applies to the negative roots.
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
