Number of revolutions within 4 seconds
In summary, the question is about the number of revolutions an object makes during the first 4 seconds and the graph provided shows the angular velocity in radians per second over time. To find the angular displacement, one can use the area of the graph, which in this case is 60 radians. Dividing this by 2pi gives the answer of 9.55 revolutions.
ch2kb0x
31
There is an attachment for the picture. question is, How many revolutions does the object make during the first 4 s?
I attempted to solve this by dividing 20 by 2pi, but apparently, that was wrong. Any help?
Hi ch2kb0x,
Check your units: when you did the division, and divided the units of 20 and 2pi, did you get radians (or revolutions)? Or was time not cancelled?
What part, or property, of this graph would represent the angle through which the object rotates?
(As an analogy, if you had a v vs. t graph, how could you use the graph directly to find the distance travelled? It's the same idea here.)
its basically a line going up like a y=x graph, all the way up to 20 omega (rad/s) till 2 seconds.
And at t=2 seconds, this is when it stays constant the rest of the way (line stays horizontal) at
20 omega(rad/s)
20 omega(rad/s)
Right, and what about the graph gives the angular displacement they are looking for?
For example, the slope of the curve (of an omega vs time graph) gives the acceleration. What gives the angular displacement?
erm...that was the only graph I was given. =\
That's the one I'm talking about. If you take the graph you are given and look at the slope of the line, you will get the acceleration.
What on the graph do you look at if you want to find the angle it rotates?
If I understand your description correctly, you have angular velocity plotted on the y-axis and time on the x axis. If that is so, the area under this graph should be equal to the angular displacement of the particle, theta. Based on your description this comes out to
Area=theta=1/2*2*20+2*20=60rad
To determine the number of revolutions just divide this angular displacement by 2pi.
#rev=60rad/6.28rad/rev=9.55rev
Related to Number of revolutions within 4 seconds
What is the definition of "Number of revolutions within 4 seconds"?
The number of revolutions within 4 seconds refers to the number of complete rotations that occur within a 4-second period. It is a measure of rotational speed or frequency.
How is the number of revolutions within 4 seconds calculated?
The number of revolutions within 4 seconds can be calculated by dividing the total number of revolutions by the time it takes to complete them. For example, if an object completes 40 revolutions in 4 seconds, the calculation would be 40/4 = 10 revolutions per second.
What is the unit of measurement for the number of revolutions within 4 seconds?
The unit of measurement for the number of revolutions within 4 seconds is revolutions per second (RPS) or revolutions per minute (RPM).
Why is the number of revolutions within 4 seconds important in science?
The number of revolutions within 4 seconds is important in science because it is a measure of rotational speed, which is a crucial factor in many scientific studies and experiments. It also helps to determine the rate of change in rotational motion and can be used to calculate other important parameters such as angular velocity and acceleration.
Can the number of revolutions within 4 seconds be converted to other units of measurement?
Yes, the number of revolutions within 4 seconds can be converted to other units of measurement such as radians per second or degrees per second. This can be done by using conversion factors and basic mathematical equations.
