Number of solutions a + b + c ≡ 0 (mod n)
  • MHB
  • Thread starter hxthanh
In summary: Your Name]In summary, the number of solutions to the given problem can be determined using a mathematical approach. We can rewrite the condition as $a+b\equiv -c \pmod n$, which means that for every fixed value of $c$, there will be exactly one pair of values for $a$ and $b$ that satisfy the condition. The total number of solutions is $\left\lceil\frac{n^3-3n^2+2n+4}{4}\right\rceil$.
hxthanh
Number of solutions
Le $n$ be a positive integer $(n\ge 6)$
How many triad $(a,b,c)$ are integers satisfying condition
$\begin{cases}a+b+c\equiv 0\pmod n\\ 1\le a<b<c\le n \end{cases}\quad$?
[sp]
Result: $\left\lceil\dfrac{(n-1)(n-2)}{6}\right\rceil$
*note: $\lceil x\rceil$ is Ceilling Function (The least integer greater than or equal to $x$)
[/sp]
Mathematics news on Phys.org
Hello,
Thank you for your question. The number of solutions to this problem can be determined using a mathematical approach. First, we can rewrite the condition as $a+b\equiv -c \pmod n$. This means that for every fixed value of $c$, there will be exactly one pair of values for $a$ and $b$ that satisfy the condition.
Now, let's consider the possible values of $c$. Since $a<b<c$, we know that $a$ and $b$ can take on values from $1$ to $c-1$. This means that $c$ can take on values from $3$ to $n$. Therefore, the number of possible values for $c$ is $n-2$.
Next, we can determine the number of possible pairs for $a$ and $b$ for a fixed value of $c$. This can be done using the formula for the number of combinations, which is $\binom{n}{2}=\frac{n(n-1)}{2}$. However, we need to subtract $1$ from this value to account for the fact that $a$ and $b$ cannot be equal. This gives us $\frac{n(n-1)}{2}-1$ possible pairs for $a$ and $b$.
Therefore, the total number of solutions is $(n-2)\left(\frac{n(n-1)}{2}-1\right)$. However, this counts each solution twice (once for $a$ and $b$ and once for $b$ and $a$), so we need to divide by $2$ to get the final answer of $\frac{(n-2)(n^2-n-2)}{4}$. Using the ceiling function, we get $\left\lceil\frac{(n-2)(n^2-n-2)}{4}\right\rceil=\left\lceil\frac{n^3-3n^2+2n+4}{4}\right\rceil$.
I hope this helps explain the solution to your problem. Let me know if you have any further questions or if you need me to clarify anything.
FAQ: Number of solutions a + b + c ≡ 0 (mod n)
What is the meaning of "a + b + c ≡ 0 (mod n)"?
The expression "a + b + c ≡ 0 (mod n)" means that the sum of three integers a, b, and c is congruent to 0 (or a multiple of n) when divided by the integer n. In other words, n divides evenly into the sum of a, b, and c.
What is the significance of finding solutions to "a + b + c ≡ 0 (mod n)"?
Finding solutions to this expression allows us to determine which combinations of three integers will result in a sum that is a multiple of n. This can be useful in various mathematical applications, such as number theory and cryptography.
How many solutions are there to "a + b + c ≡ 0 (mod n)"?
The number of solutions to this expression depends on the value of n. For any given n, there may be multiple solutions or no solutions at all. In general, the number of solutions can range from 0 to n³.
What is the difference between a solution and a congruence class in "a + b + c ≡ 0 (mod n)"?
A solution to this expression is a specific combination of three integers a, b, and c that satisfy the equation. A congruence class, on the other hand, is a set of all integers that are congruent to a particular integer (in this case, 0) when divided by n. Therefore, a solution belongs to a specific congruence class.
What are some real-world applications of "a + b + c ≡ 0 (mod n)"?
This expression has various real-world applications, such as in cryptography for generating secure keys and in error correction codes used in telecommunication systems. It is also used in number theory to study the properties of integers and in algebraic geometry to study algebraic curves.
