Number of Subgroups of Index m
cyclic
The special linear group ##SL(2, \mathbb{Z})## over ##\mathbb{Z}## is the multiplicative group consisting of all ##2 \times 2## matrices with entries in ##\mathbb{Z}## and determinant ##1##; that is,
SL(2, \mathbb{Z}) = \left\{ \begin{pmatrix} a & b \\ c & d \end{pmatrix} : a, b, c, d \in \mathbb{Z} \text{ and } ad - bc = 1 \right\}.
Let ##G## be the quotient group ##SL(2, \mathbb{Z}) / \{\pm I\}##, where ##I## is the ##2 \times 2## identity matrix. Find with proof the number of subgroups of ##G## of index ##m## for each ##m \in \{2, 3, 4, 5, 6\}##.
Let ##G## be a group and ##H## be a subgroup of ##G##. The index of ##H## in ##G##, denoted ##[G : H]##, is the number of distinct left cosets of ##H## in ##G##. That is,
[G : H] = \frac{|G|}{|H|},
if ##G## is finite. For infinite groups, ##[G : H]## is the cardinality of the set of left cosets:
[G : H] = |\{gH : g \in G\}|.
Perhaps we can use congruence subgroups here? Or perhaps we can study SL(2,Z) using its action on the projective line over the integers modulo n? I'm pretty stumped and would appreciate any help.
I searched the internet to find some information about what subgroups of ##\operatorname{SL}(2,\mathbb{Z})## look like and found https://kconrad.math.uconn.edu/blurbs/grouptheory/SL(2,Z).pdf.
The problem appears somewhat complex so I wondered which theorems and techniques your source provides to approach it. Anyway, the above paper suggests that you consider the matrices ##S,T## and ##U## and generally elements of finite order.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
