Number of turns in coil to get an output of 8V
In summary, Siri plans to build a magnetic generator that will output 8 V from the rotation of a stroller wheel. She needs help with setting up an equation and with the choice of magnets.
SiriKTH
Hello!
First of all excuse my English. I'm Swedish.
I'm doing an exprement in which I utilize the energy from the rotation in a stroller wheel to charge a 5V battery .
I plan to make a magnetic generator with a disc placed on a 10 " wheel, consisting of the 20 Neodymium magmeter on the radius of 52 mm from the wheel axis. 3 coils with iron core will be placed at a distance of 2 mm from the magnets . The stroller will roll at a speed of 5.3 km / h and I need to get about 8 V output from the generator.
I need help with setting up an equation to get the number of turns of the coil and also help with the choice of magnets. The magnets diameter should be about 10 mm.
Thanks in advance
Siri
Hello Sweden, Denmark here (also excuse my english).
I don't know if this is of any help, but the number of turns in a transformer is calculated ( by a sinusoidal flux ) by:
Veff = 4.44*f*N*A*B, (f = frquency [Hz], N = turns, A = cross section area of coil [m2], B = magnetic induction [Tesla] ).
Probably you cannot regard the flux to be sinusoidal, but then you can use:
Emf = dΨv/dt, ( Ψv = flux * (number of turns) ).
Likes SiriKTH
Hi Denmark!
Thanks for the quick reply !
How will the distance between the coil and magnet fit into the equation?
You say that iron core will be placed at a distance of 2 mm from the magnets. If the area of the magnets/iron core is large as compared to the distance, you can regard the B-field being the same in the magnet and the iron core.
I'm not calling for a smaller distance as you must have some volume in the air-gap between magnet and iron-core. That's because the power conversion ( mecanical energy → electric energy ) is due to change of energy in said airgap just outside the ironcore.
The energy density in this airgap = ½*B*H [ J/m3 ]. So the energy = ( energy density ) * ( volume of airgap ), and if the volume = 0, so is the energy. And if volume is very high (large distance), the B-field and the H-field becomes low. An optimal distance is very hard to calculate, but it exists, and it is not 0 mm.
Conceptually you are building an electromagnet that exactly matches the induced flux. Your geometry is not clear to me. I'm assuming the magnets and solenoids are beside the wheels?
Build a preprototype. The difference between the ideal and the real world is likely large enough that you will need to do this anyway. (Your magnets won't have the nominal flux, etc.) The actual equations are hard (non-linear) for an unsaturated iron core. There are core losses (hysteresis and eddy current losses).
Also, if this is a commercial type product, do not limit yourself to 8V. Switching supplies are cheap and efficient and work on a wide range of voltages. If this is for a USB type charger you will want a non-linear voltage regulator anyway. (Linear regulators are inefficient, and hand powered devices cry out for efficiency.)
For a sinusoidal output you will want the peak-to-peak (pp) output, rather than the RMS (root mean squared). Lots of equations measure total energy or the like and give the answer in RMS. (PP is about 1.4 times RMS) You then need to calculate the rectifier loss of about 0.6V before the switcher.
Remember magnets are current driven, so the voltage you get depends on the impedance of the driven circuit. An open circuit will give a different voltage reading than a short.
If this is more of a homework type experiment, try posting in the homework forum. Post a new post after reading the FAQs.
SiriKTH said:
Hello!
Siri
You will need to apply Faraday's law.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html#c2
For B,
For that you need the strength of your magnets, which you may have to obtain from its specifications.
Try searching for 'axial flux generator' and you may get some hits.
such as
http://www.academia.edu/7610343/Axi...sign_for_Low_Cost_Manufacturing_of_Small_Wind
or
http://depts.washington.edu/nnmrec/docs/Generator Final Report ME 495 Autumn 2013.pdf
Of course you will also have to determine the torque on the wheel from your generator and consider the fact that if you try to pull too much power, the wheel may skid.
Related to Number of turns in coil to get an output of 8V
1. How many turns do I need in a coil to get an output of 8V?
The number of turns required in a coil to get an output of 8V depends on various factors such as the input voltage, coil material, and the resistance of the coil. It is not possible to determine the exact number of turns without knowing these factors.
2. Does the thickness of the wire affect the number of turns needed to get an output of 8V?
Yes, the thickness of the wire used in the coil can affect the number of turns needed to get an output of 8V. Thicker wire has lower resistance, so it requires fewer turns to achieve the desired output voltage.
3. What is the relationship between the number of turns and the output voltage in a coil?
The relationship between the number of turns and the output voltage in a coil is directly proportional. This means that as the number of turns increases, the output voltage also increases proportionally.
4. Can I use any type of wire for the coil to get an output of 8V?
No, the type of wire used in the coil can affect the number of turns needed to get an output of 8V. Different types of wire have different resistances, so the number of turns required will vary.
5. How can I calculate the number of turns needed to get an output of 8V?
The number of turns needed to get an output of 8V can be calculated using the formula: N = (V × T) / (Vin × R), where N is the number of turns, V is the desired output voltage, T is the thickness of the wire, Vin is the input voltage, and R is the resistance of the coil.
  • Electrical Engineering
10K
18K
  • Electromagnetism
