MHB Number of ways to divide a square grid in half
  • Thread starter Thread starter HapaxOromenon
    Grid Square
The discussion focuses on the problem of dividing a 4x4 square grid into two equal-area parts using connected straight lines. The participant seeks to determine the total number of unique ways to achieve this division and whether there is a systematic method for listing these configurations. Different types of cuts are categorized into three classes: corner-to-corner, corner-to-edge, and edge-to-edge, with calculations yielding a total of 126 distinct cuts. The conversation emphasizes the importance of defining criteria for what constitutes a valid partition and whether rotations or reflections of cuts are considered identical. Overall, the inquiry highlights both the complexity of the problem and the need for a structured approach to counting the possible divisions.
HapaxOromenon
Consider a dotted square grid with $4$ rows and $4$ columns, as shown: View attachment 9092
By drawing a series of connected straight lines from dot to dot, it is possible to divide the square (which effectively has side length $3$) into two parts of equal area. One way of doing this is as shown: View attachment 9093
Other examples of ways of doing this are: View attachment 9094; View attachment 9095; and View attachment 9096.
The question I am investigating is how many such ways there are in total, or if such a calculation is too difficult, I would at least like to have a systematic way of listing all of the ways. But I'm not sure really where to start. Any assistance would be greatly appreciated.
Other examples of ways of doing this are: ; ; and .
Hi HapaxOromenon, and welcome to MHB!
This looks like an interesting problem, and I'm not sure whether it has a straightforward solution. But first, we need to be sure what you are trying to count. You want to partition the square grid into two parts, and you say that these parts should have the same area. In all the examples that you show, the two parts are congruent. So my first question is this: Would you allow a partition like this
[TIKZ] [scale=2]\foreach \i in {0,...,3}
\draw[thin,dotted] (\i,0) -- (\i,3) ;
\draw[thin,dotted] (0,\i) -- (3,\i) ;
\foreach \j in {0,...,3}
\fill [black,opacity=.5] (\i,\j) circle (2pt) ; }
\draw[thick] (0,2) -- (2,2) -- (2,1) -- (3,0) ;
[/TIKZ]
where the two parts have the same area (4.5 square units) but they have different shapes?
The second question is whether you would consider two partitions to be the same if one of them is just a rotation or reflection of the other one. For example, do you consider these partitions
\draw[thick] (0,2) -- (1,2) -- (2,1) -- (3,1) ;
[/TIKZ] ... [TIKZ] [scale=2]\foreach \i in {0,...,3}
\fill [black,opacity=.5] (\i,\j) circle (2pt) ; } \draw[thick] (2,3) -- (2,2) -- (1,1) -- (1,0) ;[/TIKZ]
to be the same, or different?
1) Yes, I would count this as a valid cut.
2) I would consider them to be different.
Each cut must start and finish at points on the boundary of the grid. There are two sorts of boundary points, namely the four corners of the grid, and the eight points on the edges that are not corners (I'll call these edge points).
Trying to find a systematic way to count the number of possible cuts, I split them into three classes:
1. cuts that go from corner to corner;
2. cuts that go from a corner to an edge point;
3. cuts that go between two edge points.
For the first class, there are nine cuts between the northwest and southeast corners of the grid, as in this diagram
View attachment 9106.
Rotating those grids through a right angle, you get the same number of cuts between the northeast and southwest corners of the grid. So altogether there are 18 cuts of class 1.
For the second class, there are ten cuts starting at the northwest corner of the grid and ending at an edge point, as in this diagram
View attachment 9107.
Rotating them, you get the same number of cuts starting at each of the other corners of the grid. So there are 40 cuts of class 2.
That leaves class 3, the cuts going from an edge point to a point on the opposite edge. I found 17 cuts starting from the point immediately below the northwest corner of the grid, as in this diagram
Flipping each of these about a horizontal axis, you get the same number of cuts starting from the point immediately above the southwest corner of the grid. So there are 34 cuts of class 3 going from side to side of the grid. Rotating them through a right angle, you get another 34 cuts of class 3 between the top and bottom of the grid. So altogether there are 68 cuts of class 3.
Thus the overall total number of cuts is 18 + 40 + 68 = 126 (unless I have overlooked any other possible cuts).
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
