Number of Zeros Inside Unit Circle for Polynomial P(z)
  • MHB
  • Thread starter Dustinsfl
In summary, we use Rouché's Theorem to find the number of roots of $P(z)$ inside the unit circle. By choosing $f(z) = -5z^3$, we can set up the inequality $|f(z) - P(z)| < |f(z)|$, which allows us to apply the symmetric version of Rouché's Theorem. This shows that $f(z)$ and $P(z)$ have the same number of zeros inside the unit circle, which is equal to 3.
Dustinsfl
2,281
Let $P(z) = z^8 - 5z^3 + z - 2$. We want to find the number of roots of this polynomial inside the unit circle.
Let $f(z) = -5z^3$ (Why is this being chosen?)
Then $|f(z) - P(z)| = |-z^8 - z - 2| < |f(z)| = 5$ (Why was this done?)
Hence f and P have the same number of zeros inside the unit circle (How does this follow from the above?) and this number is 3.
It's a trick to use Rouché's Theorem, then for $|z|<1$ you can pick "wisely" a term to satisty the conditions.
I need more of an explanation than it is a trick from Rouche's Theorem.
My guess would be that \( |f(z) - P(z)| = |-z^8 -z -2| \leq |z^8| + |z| + |2| = 1+1+2 < |f(z)| = |-5z^3| = 5 \). As for the reasoning of why they have the same number of zeros inside the unit circle I'm still lost as well.
I knew that piece. I wasn't sure why they set up $|f(z) - P(z)|$.
Can someone actually explain this? I have a book and I couldn't figure it out from there so I need something besides a reference.
You probably found the answer, but here's a file which may clarify your problems:
http://nathanpfedwards.com/notes/complex/Lecture20110315.pdf
FAQ: Number of Zeros Inside Unit Circle for Polynomial P(z)
What does the number of zeros when |z| = 1 represent?
When |z| = 1, the number of zeros represents the number of times a complex polynomial function crosses the unit circle on the complex plane.
How is the number of zeros when |z| = 1 related to the degree of the polynomial function?
The number of zeros when |z| = 1 is equal to the degree of the polynomial function. This relationship is known as the Fundamental Theorem of Algebra.
Can the number of zeros when |z| = 1 be any value?
No, the number of zeros when |z| = 1 is limited by the degree of the polynomial function and is always a positive integer.
How can the number of zeros when |z| = 1 be determined?
The number of zeros when |z| = 1 can be determined by factoring the polynomial function or by graphing it on the complex plane and counting the number of times it crosses the unit circle.
What is the significance of the number of zeros when |z| = 1 in complex analysis?
The number of zeros when |z| = 1 is an important concept in complex analysis as it helps to understand the behavior of complex functions and their properties. It is also used in solving equations and determining the roots of polynomial functions.
