MHB Number patterns and sequences - Tn Term
The sequence presented is 3x+5y, 5x, 7x-5y, 9x-10y, and the user is attempting to find a general term Tn in the form Tn=T1+d(n-1). It is concluded that the sequence is non-linear, which means it cannot be expressed in that linear format. Calculating the differences, d, between terms yields inconsistent results, indicating that the sequence does not follow a linear pattern. The analysis shows that the differences derived from the terms do not match, confirming the non-linearity of the sequence. Therefore, a general term in the proposed linear format is not feasible.
JanleyKrueger
The number sequence is as follows:
3x+5y; 5x; 7x-5y; 9x-10y...
I need to formulate a general term - Tn=T1+d(n-1)
In the above sequence I have no idea what.
I also think this sequence is non linear.
Please help with a solution
Thanks
Mathematics news on Phys.org
If it is non- linear then it cannot be written in that form! Taking T_1= 3x+ 5y, T_2=5x, T_3= 7x-5y, and T_4= 9x-10y, then you want T_2= 5x= 3x+ 5y+ d so d= 2x- 5y. But then you want <br /> T_3= 7x- 5y= 3x+ 5y+ 2d so d= (4x- 10y)/2= x- 10y. Those are not the same so this sequence cannot be written in that way.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
