Numbers which are not exactly calculable by any method.
In summary, there is a way to prove that a real number exists which is not calculable by any method, as shown by the difference in cardinality between the set of computable numbers and the set of all real numbers. However, it is difficult to provide a specific example of such a number, as the very act of naming it would describe how to compute it. One known example is Chaitin's constant, but there may be others with unknown properties.
bjshnog
Is there any way to prove that a real number exists which is not calculable by any method?
For example, you could have known irrational and/or transcendental numbers like e or π. You could have e^x where x is any calculable number, whether it be by infinite series with hyperbolic/normal trigonometric functions and an infinite number of random terms, and use that as the upper limit for an integral of whatever other type of function or combination of functions.
Is there a possible way to prove that there exists any real number that is not equal to any combination of functions (apart from 0/0)?
Mathematics news on Phys.org
It's easy to prove such number exists (the site micromass links to shows that the set of all "computable numbers" is countable while the set of all real numbers is uncountable. In a very real sense "almost all number are not computable".
I don't believe, however, it is possible to give an example of such a number- in fact the very naming of such a number would probably be a description of how to compute it!
Interesting. Just out of curiosity, is there a standard symbol for the "set of everything" or "set of all numbers"?
The set of all real numbers is denoted [itex]\mathbb{R}[/itex]. The latex is \mathbb{R}.
Of course that is not the set of "everything"; in standard set theory there is no set of everything. The set of real numbers is the set we're talking about when we talk about numbers in this thread. The computable numbers are a subset of the reals.
Interestingly, there is a noncomputable real number that has a name and whose properties can be talked about. It's called Chaitin's constant.
http://en.wikipedia.org/wiki/Chaitin's_constant
I actually began thinking about non-computable numbers, so I Googled it and found Ω. That is what led me to post here, to see if anyone knew of any other non-computable numbers with known properties.
FAQ: Numbers which are not exactly calculable by any method.
What are numbers which are not exactly calculable by any method?
Numbers which are not exactly calculable by any method are known as uncomputable numbers. These are numbers that cannot be precisely determined or calculated using any known algorithm or method.
How do uncomputable numbers differ from irrational numbers?
Uncomputable numbers are a subset of irrational numbers. While irrational numbers cannot be represented as a fraction of two integers, uncomputable numbers cannot be calculated or approximated using any method.
Are there any examples of uncomputable numbers?
Yes, there are many examples of uncomputable numbers. One of the most well-known examples is the Chaitin's constant, which represents the probability that a randomly chosen program will halt.
What is the significance of uncomputable numbers in mathematics?
Uncomputable numbers have played a significant role in the development of mathematics, particularly in the field of computability theory. They have also been instrumental in proving the limitations of computation and the existence of unsolvable problems.
Can uncomputable numbers ever be calculated or approximated?
No, uncomputable numbers cannot be calculated or approximated using any method. This is because they are inherently unpredictable and cannot be represented or expressed in any finite way.
