Numerical analisis and complex integrals
In summary, complex integrals can be approximated by using numerical methods, but the time it takes to achieve a certain level of accuracy and precision depends on a few factors like the rate of convergence of the integral and the accuracy needed for the approximation.
eljose
492
I have a dobut,can a complex integral be evaluated by using numerical analisis?..for example the integral LnR(s)/R(s) where R(s) is Riemann Zeta function with the limits (c+i8,c-i8) i would use the change of variable s=c+iu so the integral becomes a real integral with the limit (-8,8) now how could i evaluate it?..thanks.
Yes complex integrals can be evaluated (should say "approximated") using numerical methods. The time it takes to achieve a certain level of precision depends on a few factors. Like if you're integrating over an infinite contour, how fast does the integral converge? The slower it converges, the farther out you'll have to go to get a certain level of accuracy and the more time it will take you.
There's another problem if you're trying to approximate an integral involving Zeta numerically- you'll have to approximate Zeta itself numerically. The more accurate you want your integral, the more accurate you'll need to approximate zeta and the more points you'll need to approximate Zeta at.
You've often claimed how your integrals can be evaluated numerically in a very cavalier way. Are you beginning to see some of the difficulties? I'm no wiz at numerical methods, you might want to do some research yourself and try to get at least some understanding of the time it would take to calculate your integrals to even a few decimal places of accuracy, let alone the precision you'd need to calculate pi(x) when x is a mere 4 or 5 digits.
Thanks for replying shmoe,but let,s suppose we have that Pi(x) is equal to a triple integral then would be enoguh to know the integral with an accuracy of 01. for example.
Another question i have...if f(x) is equal to a complex integral does the time to evaluate an integral depend on x?..for example if we want to evaluate numerically the inverse Laplace transform given by the integral ds1/R(s)exp(st) does the tiem emplyed to eavluate this integral depend on the value of t?...
You're triple integral actually evaluted pi(x)/x^4 I seem to recall. So, to work out pi(10)^n you'd need to evaluate the integral to an error of no more than 10^{-4n} units. (i've no idea wat accuracy of 01. means)
Is the x inside your integral? (even as a free variable)? if so that'll affect the cost of the integral.
with 0.1 i meant the error in the sense [Ireal-Iapprox]<0.1.
the x in the integral appears in the form (x^s)f(s) where the integration is made in s across the real line Re(s)=c
Using the integral transform Int(1,8)f(x)x^-(s+1) i have managed to get a triple integral representation for Pi(x) but it involves calculating the poles for R(4-q) and LnR(ns) that,s why i have decided to search for a numerical approach the integrand is F(n,q,s)x^s/s but i don,t know if the error in approximating it will depend on the value x
Of course it will depend on the x, since it has an x^s inside the integral, so naturally it will have some effect on the approximation, and an exponentially bad one at a guess.
FAQ: Numerical analisis and complex integrals
What is numerical analysis?
Numerical analysis is a branch of mathematics that deals with developing algorithms and methods for solving mathematical problems using numerical approximation techniques. It involves using computers to solve mathematical problems that are too complex or difficult to solve by hand.
What are the applications of numerical analysis?
Numerical analysis has many applications in various fields such as engineering, science, finance, and computer graphics. It is used to solve problems related to optimization, interpolation, differential equations, and statistics, to name a few. It is also used in designing and testing algorithms for machine learning and artificial intelligence.
What is a complex integral?
A complex integral is a mathematical concept used to evaluate the area under a complex-valued function over a given region in the complex plane. It is similar to a regular integral in calculus, but the function being integrated is complex-valued, meaning it has a real and imaginary component.
How are complex integrals evaluated?
Complex integrals can be evaluated using various methods such as contour integration, Cauchy's integral formula, and residue theorem. These methods involve using complex analysis techniques to break down the integral into smaller, more manageable parts and then evaluating them separately. The final result is the sum of these smaller integrals.
What are the practical applications of complex integrals?
Complex integrals have many practical applications, such as in physics, engineering, and signal processing. They are used to calculate quantities such as work, force, and power in electromagnetism and fluid dynamics. They are also used in solving problems related to electric circuits, control systems, and image processing.
