Numerical solution of vector potential
In summary, the conversation is about finding the field A given field B through the equation B = square root of x times A. The speaker needs a numerical solution for this, but it is not enough to just use the given equation. The "gauge" needs to be fixed by adding divA=0 and dA/dt=0. The speaker is also looking for suggestions on numerical methods to solve the problem, such as using the "curl" and differential equation solver methods like Runge-Kutta.
santanaa
I have a field ,B, I need to find the other field,A, such that
-> __ ->
B = \/ x A
I need numerical solution, given B sampled on a 3D computational grid (finite difference hexahedra) find A. What numerical methods could be used?
This equation is not sufficient to find A. You have first to fix the "gauge", for example, add divA=0 and dA/dt = 0 (a static field).
thanks for the pointer. Any idea about the numerical method to solve?
You do know what the "curl" is, right?
Assuming that you do, write out the differential equation in whatever coordinate system that is relevant to the problem, and then use any of the differential equation solver method, such as Runge-Kutta, etc.
Zz.
Related to Numerical solution of vector potential
1. What is the numerical solution of vector potential?
The numerical solution of vector potential is a method used in computational electromagnetics to approximate the vector potential at a point in space. It involves discretizing the problem into a finite set of points and using mathematical algorithms to solve for the vector potential at each point.
2. Why is the numerical solution of vector potential important?
The numerical solution of vector potential is important because it allows for the analysis of complex electromagnetic systems that cannot be solved analytically. It also provides a way to simulate and predict the behavior of electromagnetic fields in real-world applications.
3. What are the advantages of using numerical solution of vector potential?
One advantage of using numerical solution of vector potential is that it can handle complex geometries and boundary conditions. It also allows for the incorporation of non-linear materials and time-varying fields, making it a versatile tool for electromagnetic simulations.
4. What are some common numerical methods used for solving vector potential?
Some common numerical methods used for solving vector potential include the finite difference method, finite element method, and boundary element method. Each method has its own advantages and disadvantages, and the choice of method depends on the problem being solved.
5. Are there any limitations to the numerical solution of vector potential?
Yes, there are some limitations to the numerical solution of vector potential. It can be computationally intensive and time-consuming for large problems. It also relies on the accuracy of the discretization and the chosen numerical method, which can affect the accuracy of the results.
