Object moving on a spiral figure
In summary, the homework statement asks for an object to describe a spiral movement in polar coordinates. The Attempt at a Solution calculates the radial and tangential velocities and calculates the speed of the point of the object. The results are checked to see if they are correct. If not, the problem is explained in more detail and the student is encouraged to try again.
Smouk
We've got an object/person in the center of a cicrcle that spins around with an angular velocity ω. That same object is moving at a constant speed k with the direction of the radius, that is from the center to the outside of the sphere. That object describes then a spiral movement. We are asked to calculate speed depending on time and also accelaration all done in polar coordinates.
-We have:
r→=r*Ur→
r=kt
φ=ωt
dr→/dt=v→
dv→/dt=a→
A "→" character means that the previous symbol is a vector.
v→ = dr→/dt = dr/dt * Ur→ + r * dUr→/dt = k * Ur→ + rωUφ→ = k * Ur→ + ktωUφ→
a→ = dv→/dt = 0 + kωUφ→ + kωUφ→ + ktω2Ur→ = 2kωUφ→ + ktω2Ur→ =
= 2kωUφ→ + 2Ur→
The first part (2kωUφ→) would refer to tangential acceleration while the second part (rω2Ur→) would refer to radial acceleration.
Are the answers correct? If not please tell me where I'm wrong and why and if you can also give me some suggestions on presenting problems on a forum like this one.
We've got an object/person in the center of a circle that spins around with an angular velocity ω. That same object is moving at a constant speed k with the direction of the radius, that is from the center to the outside of the sphere.
1. Which is it, a sphere or a circle?
2. Bold face would normally indicate a vector ... angular velocity would be a pseudovector so that's fine, is k a speed or a velocity?
That object describes then a spiral movement. We are asked to calculate speed depending on time and also acceleration all done in polar coordinates.
You seem to be doing work involving a change in reference frame.
It will help you evaluate your results if you are more pedantic about saying which reference frame you are doing what in.
It can also help you check your results by having more than one way to do the problem,
I'll illustrate:
... let's say the "object" is a pen moving in a straight line outwards from the center of a rotating disk so it draws a line on the disk.
That line will be a spiral.
Is that the idea?
The problem, then, would be to work out the speed that the point of the pen moves across the disk.
If the radial speed is k, then the radial position of the point is r'=r=kt.
In the first frame the angular position is always the same, so choose $$\theta^\prime=0$$, and let the reference frames.
Notice I am using the prime to indicate the first reference frame, the rotating frame is unprimed.
In the rotating frame, the point has a tangential component to the velocity: $$v_\perp = r\omega = k\omega t$$
The speed in the rotating frame is the magnitude of the velocity... which is $$|\vec v|^2 = v_r^2 + v_\perp^2$$
... which will let you check your results.
You can use a similar approach to work out acceleration.
I'm guessing that your task is actually to show that you know how to use the polar form of the differentiation and magnitude calculations.
What I'm doing here is showing you how to check.
FAQ: Object moving on a spiral figure
What is a spiral figure?
A spiral figure is a shape that curves continuously around a central point, gradually moving away from or towards the center.
How does an object move on a spiral figure?
An object can move on a spiral figure by following the curved path of the spiral, either by continuously moving away from or towards the center.
What causes an object to move on a spiral figure?
An object can move on a spiral figure due to the influence of external forces, such as gravity or magnetic fields, or due to its own inherent motion, such as a spinning top.
What are some real-life examples of objects moving on a spiral figure?
Some examples of objects moving on a spiral figure include planets orbiting around the sun, particles spiraling around a magnetic field, and water draining down a spiral-shaped drain.
How is the motion of an object on a spiral figure described?
The motion of an object on a spiral figure is described using mathematical concepts such as velocity, acceleration, and centripetal force, as well as the angle and radius of the spiral.
