Object slides in rolling cylinder
In summary, the puck is placed onto the inner surface of the thin cylinder of mass M and of radius R. Initially, the cylinder rests on the horizontal plane and the puck is located at the height R above the plane. The net force in the horizontal (x) direction is friction, and the only torque on the cylinder is friction. The point mass just falls straight downwards... not what I expected but I'll roll with it.
  • #36
@TSny
First I should say, when I said "accelerating axis of rotation" that is not really what I meant. I wasn't sure how to articulate myself (so I didn't try) but this is what I meant:
For the first instant we have a stationary axis somewhere, and then at a future instant we move the axis to somewhere else, but the axis is still stationary. So it's like it's instantaneously stationary, yet it's location is changing.
I'm still not sure if that makes sense... but that is what I've been imagining.
So in your example it's like we start the axis at the level of the particle, and then the particle falls a bit, and then we move the axis down a bit, but the axis is meant to be stationary at each instant.
Anyway, I think your example of a falling particle has made me realize when it is valid to do this:
It is valid to do this if the angular momentum is the same about all locations(that we use) of the axis. That way the torque we calculate through all these different stationary-axes is the rate of change of the same quantity.
For example, in the OP I took the torque (on the cylinder) to be about a ("instantaneously-stationary") axis which is continuously through the cylinder's CoM. The reason this works is because the angular momentum (of the cylinder) is the same through all points on that line which the CoM traces out.
Am I just making up nonsense or does this seem correct?
  • #37
I wonder whether some brave person is going to have to go all the way back to Noether's Theorem, to work out exactly what any valid rule of Conservation of Angular Momentum would say about the axis/axes about which angular momentum is conserved.
It's certainly not obvious that it is conserved about an axis that is accelerated relative to an inertial frame, or under what special conditions it might be conserved about such an axis.
  • #38
haruspex said:
But it's ok if it's the CoM of the object in question, because the acceleration of the body does not correspond to a (virtual) torque about that point, right?
Yes, I think that's a good way to look at it.
[EDIT: You can concoct examples where the torque equation about the CoM is not valid (even if the CoM has no acceleration!). To do this you need to have a frame of reference that's rotating relative to inertial frames. For example, consider a merry-go-round with a tangential force applied to the rim. If you choose a reference frame that rotates with the merry-go-round then the angular momentum of the system about the CoM in this frame is always zero even though there is a non-zero torque.
Maybe all this is obvious enough that I didn't need to bring it up, but I thought I would mention it anyway.]
  • #39
Nathanael said:
@TSny
I can see how this can be confusing. At any instant of time you can pick your origin anywhere you want. As long as this origin is thought of as a fixed point of an inertial reference frame then the torque equation will be valid relative to that origin and frame of reference. All velocities, accelerations, and torques are measured relative to that particular inertial frame and that origin for that instant of time. These velocities, accelerations, and torques do not depend in any way on how you are going to pick the frame of reference and origin at the "next" instant of time. You could use a random number generator to arbitrarily pick the inertial frame and origin at each instant of time. So your "instantaneously stationary" axes could be jumping all over the place from one instant to another.
However, if at some instant of time you choose an origin that is fixed to some non-inertial frame then you would calculate your velocities, accelerations, etc. relative to this non-inertial frame at that instant of time. Then you would generally not find the torque equation to be valid.
Hope this helps some.
  • #40
Right, thanks. I try to avoid non-inertial frames, but if I do use them I will keep in mind to be careful with angular momentum.
But about these "instantaneously stationary" axes: I believe this method (of switching axes at each instant) also would not work in general. It would only work if the set of points that we (or the RNG) choose from have this property: at any instant in the relevant time interval the angular momentum of our system is the same about all of these points.
I never realized this restriction before, so I'm glad to learn the limitation of using this method.
Of course, the only purpose of using this method is to simplify calculations, but in a problem like this one it really makes a difference over using an axis at a constant location (as I began to do in post #3).
  • #41
If we take it back to first principles, for a mass element dm at ##\vec r## in a fixed reference frame O, torque ##d\tau=\vec r\times \ddot{\vec r}.dm##. So ##\tau=\int \vec r\times \ddot{\vec r}.dm##. If we now allow the reference point an acceleration ##\vec a##, ##\tau'=\int \vec r\times (\ddot{\vec r}-\vec a).dm = \tau - (\int \vec r.dm )\times\vec a##.
##\tau'=\tau## if:
  • O is the mass centre (P), or
  • ##\vec a=0##, or
  • the acceleration is along the line OP
In the present case, the point of the cylinder making contact is valid.
Likes Nathanael
