*oblique asymptotes of radical expressions
In summary, we can see that the oblique asymptotes for $\sqrt{x^2+6x}$ are $y=x+3$ and $y=-x-3$, even though it is not a rational expression. This can be derived by completing the square and graphing the upper half of a hyperbola.
karush
MHB
3,269
it seems most oblique asymptotes are mostly with rational expressions but
$\sqrt{x^2+6x}$ has the asymptote of $y=x+3$ and $y=-x-3$
I don't know how this is derived since it is not a rational expression
thanks ahead:cool:
Mathematics news on Phys.org
thanks ahead:cool:
For large \(x\) we have the asymtotic behavior: \[\sqrt{x^2+6x} \sim \sqrt{x^2+6x+9}=\pm (x+3)\]
Note deliberate error of use of the \(\pm\) sign, a square root is by definition positive, so as \(x \to +\infty,\ \sqrt{x^2+6x} \sim x+3\), and \(x \to -\infty,\ \sqrt{x^2+6x} \sim -(x+3)\). See plot below.
CB
thanks ahead:cool:
As usual, you can proceed by studying the difference $f(x)-(ax+b)$ since you've got that information. For calculus, you would then use the conjuguated expression.
For $x>0$:
$\sqrt{x^2+6x}-x-3=\frac{(\sqrt{x^2+6x}-x-3)(\sqrt{x^2+6x}+x+3)}{\sqrt{x^2+6x}+x+3}=\frac{x^2+6x-(x+3)^2}{\sqrt{x^2+6x}+x+3)}=\frac{-9}{\sqrt{x^2+6x}+x+3)}$
therefore $\lim_{x->+\infty}{f(x)-x-3}=0$
you can even deduce from above that the curve is under the asymptote ($f(x)-(ax+b) < 0 $)
Hello, karush!
It seems most oblique asymptotes are mostly with rational expressions,
but $y \:=\:\sqrt{x^2+6x}$ has the asymptotes $y=x+3$ and $y=-x-3$
I don't know how this is derived since it is not a rational expression.
We have: .$y \:=\:\sqrt{x^2+6x} $
Square both sides: .$y^2 \:=\:x^2+6x \quad\Rightarrow\quad x^2 + 6x - y^2 \:=\:0 $
Complete the square: .$x^2 + 6x \color{red}{+ 9} - y^2 \:=\:0 \color{red}{+9} \quad\Rightarrow\quad (x+3)^2 - y^2 \:=\:9 $
Divide by 9: .$\dfrac{(x+3)^2}{9} - \dfrac{y^2}{9} \:=\:1$The graph is the upper half of this hyperbola,
whose asymptotes are: $y \:=\:\pm(x+3)$
I can explain the concept of oblique asymptotes of radical expressions. An oblique asymptote is a line that the graph of a function approaches, but does not intersect, as the input values approach infinity or negative infinity. In the case of radical expressions, the oblique asymptotes can be determined by finding the limits of the function as the input values approach infinity or negative infinity.
In the given example of $\sqrt{x^2+6x}$, we can see that as the input values approach infinity, the expression inside the square root, $x^2+6x$, becomes much larger than $x$ itself. This means that the square root will be dominated by the term $x^2$ and the function will behave similarly to $\sqrt{x^2}$ which simplifies to $x$. Similarly, as the input values approach negative infinity, the expression inside the square root will be dominated by the term $x$ and the function will behave like $\sqrt{x}$.
By finding the limits of the function as the input values approach infinity and negative infinity, we can see that the function approaches the lines $y=x$ and $y=-x$ respectively. However, the given function is shifted horizontally by a constant value of 3. This means that the oblique asymptotes will be shifted by the same amount, resulting in the asymptotes $y=x+3$ and $y=-x-3$.
In conclusion, even though the given expression is not a rational expression, we can still determine the oblique asymptotes by analyzing the behavior of the function as the input values approach infinity and negative infinity. This is a common approach in mathematics and science, where we use limits to understand the behavior of a function at extreme values. I hope this explanation helps clarify the concept of oblique asymptotes of radical expressions.
FAQ: *oblique asymptotes of radical expressions
What are oblique asymptotes of radical expressions?
Oblique asymptotes of radical expressions are lines that the graph of a radical function approaches but never touches as x approaches positive or negative infinity. They are also known as slant asymptotes.
How do you find the oblique asymptotes of a radical expression?
To find the oblique asymptotes of a radical expression, you must first rewrite the expression in the form of a rational function. Then, use long division to divide the numerator by the denominator. The resulting quotient will be the equation of the oblique asymptote.
Can a radical expression have more than one oblique asymptote?
Yes, a radical expression can have more than one oblique asymptote if the degree of the numerator is larger than the degree of the denominator. In this case, there will be multiple lines that the graph approaches as x approaches positive or negative infinity.
Do all radical functions have oblique asymptotes?
No, not all radical functions have oblique asymptotes. Only functions with a degree of the numerator that is larger than the degree of the denominator will have oblique asymptotes.
How do oblique asymptotes affect the graph of a radical function?
Oblique asymptotes do not intersect or touch the graph of a radical function, but they do influence the behavior of the graph as x approaches positive or negative infinity. The graph will approach the oblique asymptote but will never actually reach it.
