Observation Deck Assignment - Tension in Cables
In summary, the conversation involves a group working on an engineering assignment to research, build, test, and write a report on an observation deck. They are currently stuck on determining the tension in the cables, which needs to produce a moment with a uniformly distributed load of 20-30kg applied to the beam. The beam is attached to a middle pylon by a hinge and must fail only by the cables snapping. The group is unsure of what formulas or equations to use and mentions equations of equilibrium and M=Fd. They have not attempted to solve the problem and are considering creating a diagram to better understand the problem.
b6ttery
For my engineering assignment we are working in a group to research, build, test, and write a report on an observation deck.
The little fork in the road we've hit is determining the tension in the cables. There needs to be a moment produced once there is between 20 and 30kg of a uniformly distributed load applied to the beam. We must take into consideration the weight of the beam.
The beam is attached to the middle pylon by a hinge. The deck must fail by the cables snapping/breaking, and nothing else (ie, no breaking of the beam).
We're stuck because we have no clue what sort of formulas/equations we should be using!?
Please help =)
I know that there's the equations of equilibrium,
Sum of Fx = 0
Sum of Fy = 0
Sum of M = 0
And that,
M=Fd
I've had no attempt at solving this equation =(
Oh, also, we know where the cables are on our deck and hence, the angles they make they the beam. Would anyone like a diagram?
We need a good diagram, and need to know if this is a 2- or 3-dimensional problem.
Related to Observation Deck Assignment - Tension in Cables
What is the purpose of an observation deck?
An observation deck is a platform located at a high point, such as the top of a building or a mountain, that is designed to provide a panoramic view of the surrounding area. It is typically used for sightseeing, photography, and other recreational activities.
How are cables used in the construction of an observation deck?
Cables play a crucial role in the construction of an observation deck. They are used to support the weight of the platform and keep it stable. Cables are also used to anchor the deck to the ground or the building, providing additional support and preventing it from swaying in the wind.
What factors contribute to tension in cables on an observation deck?
The tension in cables on an observation deck is influenced by several factors, including the weight of the deck and its occupants, wind and weather conditions, and the design and materials used for the cables. Additionally, the angle and direction of the cables also affect the tension.
How is tension in cables on an observation deck measured and monitored?
Tension in cables on an observation deck is typically measured using specialized equipment such as load cells or strain gauges. These devices can provide real-time data on the tension levels in the cables, which can then be monitored by engineers and maintenance personnel to ensure the safety and stability of the deck.
What safety precautions should be taken to ensure the stability of an observation deck?
To ensure the stability of an observation deck, it is important to regularly inspect and maintain the cables and other structural components. Proper design and construction techniques, as well as adherence to building codes and safety standards, are also crucial. In the event of extreme weather conditions, the deck may need to be temporarily closed for safety reasons.
