Observation, wavelength and resolution
In summary: Ernst Ruska, found the resolution of his first microscope to be 40 nm, according to the Abbe criterion.In summary, the wavelength of the incident light must be of the same scale as the object in order to accurately locate a small particle using a detector. This is due to the diffraction limited process of imaging, and the resolution is limited by the wavelength of the incident light. The Abbe criterion and Scherzer resolution can be used as rough comparisons for resolution in light and electron microscopes. However, errors such as aberration make it difficult to achieve high resolution in the pm range.
the4thamigo_uk
47
Why are short wavelengths (of e.m. radiation say) required for observing the location of a small particle? Classically, I could imagine sending a wave train of light (or a photon) of different frequencies onto an atom in free space. Providing the electrons in the energy levels of the atom can absorb and re-emit those frequencies, then I should be able to locate the particle using a detector with the same precision whatever the wavelength of the incident photon?
So what is the underlying reason why the wavelength of the incident light must be of the same scale as the object?
Do you know the relationship between the wavelength (of beam/ray that you use to probe the sample/particle etc) and resolution ? Resolution is limited by wavelength.
If not please find some information of the following:
1. Abbe criterion (it gives you some rough comparison of resolution in light, electron microscopes)
2. Scherzer resolution (may be you find some information)
But errors are unavoidable, so you often cannot go much into detail up to pm range.
Errors are Aberration,
the4thamigo_uk;2822448what is the underlying reason why the wavelength of the incident light must be of the same scale as the object?[/QUOTE said:
I can recommend "The Feynman Lectures on Physics," Volume 2, Section 29-5 ("The electron microscope).
Observation, wavelength, and resolution are all crucial concepts in the field of science, particularly in the study of particles and atoms. Observation refers to the act of gathering information or data through the use of our senses or scientific instruments. Wavelength, on the other hand, refers to the distance between two consecutive peaks or troughs of a wave, and it is a fundamental property of electromagnetic radiation. Resolution, in this context, refers to the ability to distinguish or resolve two separate objects or features in a given system.
In order to understand why short wavelengths are required for observing the location of a small particle, we must first understand the nature of electromagnetic radiation and its interaction with matter. According to classical physics, electromagnetic radiation behaves like a wave, and when it interacts with matter, it can be absorbed and re-emitted by the electrons in the atom. This process is known as scattering.
Now, imagine sending a wave train of light (or a photon) of different frequencies onto an atom in free space. If the electrons in the energy levels of the atom can absorb and re-emit those frequencies, then theoretically, we should be able to locate the particle using a detector with the same precision, regardless of the incident photon's wavelength.
However, in reality, this is not the case. The reason for this is due to the wave-particle duality of light, meaning that it can behave as both a wave and a particle. When we are dealing with small particles, such as atoms, the wave-like nature of light becomes more significant. This means that the wavelength of the incident light becomes a crucial factor in determining the accuracy of our observation.
The wavelength of the incident light must be on the same scale as the object we are trying to observe because of the phenomenon known as diffraction. Diffraction occurs when a wave encounters an obstacle or a slit that is comparable in size to its wavelength. In the case of light, this means that when we try to observe a small particle with a larger wavelength of light, the light waves will diffract around the particle, causing blurring and reducing the resolution of our observation.
In order to overcome this diffraction limit and achieve a higher resolution, we need to use shorter wavelengths, which are on the same scale as the object we are trying to observe. This allows the incident light to interact more directly with the particle, providing more precise information about its location.
In conclusion, the underlying reason why the wavelength of the incident light must be of
Related to Observation, wavelength and resolution
1. What is the importance of observation in scientific research?
Observation is a crucial aspect of scientific research as it allows us to gather information and data about the natural world. It helps us to identify patterns, make predictions, and test hypotheses. Without observation, we would not be able to understand or explain the phenomena that we observe.
2. How does the wavelength of light affect what we can observe?
The wavelength of light determines the color and energy of the light. Different wavelengths of light interact with matter in different ways, allowing us to observe different properties and phenomena. For example, shorter wavelengths (such as X-rays) can penetrate through solid objects, while longer wavelengths (such as infrared) can be used to detect heat.
3. What is the relationship between resolution and observation?
Resolution is the ability to distinguish between two objects or details that are close together. The higher the resolution, the more detail we can observe. This is important in scientific research as it allows us to study and analyze smaller and more intricate features of the natural world.
4. How do scientists use technology to improve observation and resolution?
Scientists use a variety of tools and technologies to enhance observation and resolution. For example, telescopes and microscopes use lenses and mirrors to magnify and focus light, allowing us to see objects that are too small or far away to be observed with the naked eye. Other advanced techniques, such as electron microscopy and spectroscopy, use specialized instruments to observe and analyze matter at the atomic level.
5. Can observation and resolution be improved without technology?
Yes, observation and resolution can also be improved through careful and systematic observation techniques. By using proper lighting, adjusting viewing angles, and taking multiple measurements, scientists can improve their ability to observe and resolve details in the natural world. This is especially important in fields such as ecology and field biology where technology may not always be readily available.
  • Atomic and Condensed Matter
  • Electromagnetism
  • Quantum Physics
