Observing which-way for fullerene molecules (buckyball)
  • Thread starter San K
  • Tags
    Molecules
In summary, the conversation discussed the use of a method to determine which slit a buckyball molecule went through, without disturbing the interference pattern. It was mentioned that there are multiple interpretations of this phenomenon and experiments have shown that as the confidence of one path increases, the visibility of the interference pattern decreases. This demonstrates the fundamental quantum principle that it is not possible to have both information about the path and the interference pattern at the same time. It was also noted that this concept has been tested on buckyballs, further proving that they experience quantum effects.
San K
911
the buckyball has between 20-60 atoms.
This is a fairly large size. even if we "bounce" a photon or two off it, the molecule should not be effected.
Thus can we use some method to find out which slit the molecule went through, without disturbing the interference pattern?
or is it that, even if the photon were to not disturb the buckyball, we still would loose the interference pattern...because it's not about photon disturbing the molecule but about the fact that you simply cannot have which-way and interference pattern (at the same time) ...as a fundamental property of quantum mechanics?
San K said:
... you simply cannot have which-way and interference pattern (at the same time) ...as a fundamental property of quantum mechanics?
That is consistent with all of the experimental results. There are many different interpretations of *how* that phenomenon comes about.
Even more interesting, there are some "weak" detection schemes, where you do not get concrete information about which path was taken, but you can measure with say 70% certainty that it went through the left slit, rather than the right one. The amazing thing about this case is that the intereference pattern, while still visible, begins to decohere .. that is, the borders between the light and dark fringes get blurrier and blurrier as you increase the confidence of one of the paths. I think Dr. Chinese's website has links to and/or descriptions of the papers that demonstrate such "weak" detection.
I suspect that what would find if tried this experiment, is that the visibility of the interference pattern will scale with the intensity of the light. The reason is that you would (in any setup I can think of) need to detect quite a few photons to actually be able to infer "which-path" information.
There are some quite fundamental relations in QM which relate the amount of information you can (potentially) get out of a system (per unit time) with the rate of dephasing (T2, which in turn is related to fringe visibility). Perfect information gives instant dephasing (not that this can happen).
Note that there are experiments quite similar to what you are proposing. Most notably experiments with ion-traps where the visibility of superpositions scales with the intensity of the probe laser as outlined above.
Edit: Spectracat was faster...
thanks SpectraCat, thanks f95toli... yes, I am aware of the above concept and agree, thanks to Dr Chinese.
however i was not aware that this has been tried on buckyballs as well.
however this also proves a very fundamental point:
Buckyballs (and not just our photons, electrons) are indeed experiencing quantum effects...
because...you cannot have both with 100% accuracy (probability would be a better word)
both = fringes and which-way = they are complimentary
FAQ: Observing which-way for fullerene molecules (buckyball)
What is the purpose of observing which-way for fullerene molecules?
The purpose of observing which-way for fullerene molecules, also known as buckyballs, is to understand their behavior and properties at the molecular level. This information can provide valuable insights for various fields such as materials science, nanotechnology, and pharmacology.
How is the which-way observation of fullerene molecules conducted?
The which-way observation of fullerene molecules can be conducted through various techniques such as electron diffraction, scanning tunneling microscopy, or fluorescence spectroscopy. These methods allow scientists to track the movement and location of the molecules in real-time.
What are the potential implications of the which-way observation for fullerene molecules?
The observation of which-way for fullerene molecules can help in developing more efficient manufacturing processes for these molecules, as well as understanding their role in various biological processes. It can also aid in the design of novel materials and technologies.
Are there any challenges in conducting which-way observation for fullerene molecules?
Yes, there are several challenges in conducting which-way observation for fullerene molecules. These include the small size of the molecules, their fast movement, and the need for specialized equipment and techniques. Additionally, the observation itself may affect the behavior of the molecules, making it difficult to obtain accurate results.
How can the results of the which-way observation be applied in real-world applications?
The results of the which-way observation can be applied in various real-world applications. For example, the understanding of fullerene molecules' behavior can help in developing more efficient drug delivery systems or improving the performance of electronic devices. It can also aid in the development of new materials with unique properties for various industries.
26K
