Obtaining stability criterion for 2nd order ODEs in coefficient form
In summary, the document discusses the process of deriving stability criteria for second-order ordinary differential equations (ODEs) presented in coefficient form. It outlines the mathematical techniques used to analyze the stability of solutions and emphasizes the importance of the coefficients in determining the behavior of the system. The criteria are essential for ensuring that the solutions remain bounded over time, contributing to the understanding of dynamic systems in various applications.
zenterix
708
84
A system is called stable if its long-term behavior does not depend significantly on the initial conditions.
Consider a system modeled by the following inhomogeneous 2nd order linear differential equation with constant coefficients
$$y''+by'+ay=r(t)\tag{1}$$
The general solution has the form
$$y=c_1y_1+c_2y_2+y_p\tag{2}$$
##y_p## is a particular solution to (1) and ##c_1y_1+c_2y_2## is the general solution to the associated homogeneous equation.
If ##c_1y_1+c_2y_2## approaches zero asymptotically for every choice of ##c_1## and ##c_2## then the system is stable because the long-term behavior is due solely to the ##y_p## term (which does not depend on initial conditions).
Note that ##c_1y_1+c_2y_2## is called the transient and ##y_p## is called the steady-state solution.
My question is about the conditions for stability.
Below I go through the argument to show that the system in (1) is stable ##\iff## coefficients ##a## and ##b## are positive.
I am posting the argument here to try to make sure it is correct.
As we noted above, stability is all about the solution to the homogeneous equation.
For the equation
$$y''+by'+ay=0\tag{3}$$
we have discriminant
$$\Delta = b^2-4a\tag{4}$$
and the roots are
$$r=\frac{-b\pm\sqrt{b^2-4a}}{2}\tag{5}$$
We have three cases.
Case 1 (Distinct Real Non-Complex Roots) If we have a positive discriminant, then we have two distinct real roots. The solution is ##c_1e^{r_1t}+c_2e^{r_2t}## and the only way this tends to zero as ##t\to\infty## is if ##r_1<0## and ##r_2<0##.
What does this mean for the coefficients of (3)?
##\Delta>0## means ##b^2>4a##.
##r_1<0## implies
$$-b+\sqrt{\Delta}=-b+\sqrt{b^2-4a}<0$$
$$b>\sqrt{\Delta}>0$$
$$b^2>b^2-4a$$
$$4a>0$$
$$a>0$$
Therefore, we have shown that it must be that both ##a## and ##b## are positive.
Case 2 (Repeated Real Non-Complex Roots) If the discriminant is zero then ##b^2=4a## and we have a single root ##r=\frac{-b}{2}##. Note that we already have ##a>0## from ##0<b^2=4a##.
The solution to (3) is ##e^{rt}(c_1+c_2t)## and this approaches zero as ##t\to\infty## only if ##r<0##. This happens if ##b>0##.
Once again, stability requires both ##a## and ##b## to be positive.
Case 3 (Distinct Complex Non-Real Roots) If the discriminant is negative then ##0<b^2<4a##. Thus ##a>0##
The roots are
$$r_1=\frac{-b+ i\sqrt{4a-b^2}}{2}$$
$$r_2=\frac{-b- i\sqrt{4a-b^2}}{2}$$
and the solution is
$$e^{-bt/2}(c_1\cos{kt}+c_2\sin{kt})$$
where ##k=\frac{1}{2}\sqrt{-\Delta}##.
For stability we need ##-b<0## and so ##b>0##.
Note that ##b/2## is the real part of the roots. Therefore, we can express the condition for stability as the requirement that the real part of the complex roots is negative.
We can summarize all cases by saying that for stability the real part of the roots must all be negative.
Alternatively we can say that if ##a## and ##b## are positive then we will have stability.
You can write the solutions of [itex]\lambda^2 + b\lambda + a = 0[/itex] as [tex]
\lambda_{\pm} = -\frac{b}{2} \left( 1 \pm \sqrt{1 - \frac{4a}{b^2}}\right).[/tex] It follows that if the roots are a complex conjugate pair then the real part has the oppsite sign from [itex]b[/itex], whereas if the roots are real then there is always a root ([itex]\lambda_{+}[/itex]) which has the opposite sign from [itex]b[/itex]. Thus [itex]b > 0[/itex] is a necessary condition for stability. It is not however sufficient, since the other real root ([itex]\lambda_{-}[/itex]) will have the same sign as [itex]b[/itex] if [itex]a < 0[/itex].
FAQ: Obtaining stability criterion for 2nd order ODEs in coefficient form
What is a stability criterion for 2nd order ODEs?
A stability criterion for 2nd order ordinary differential equations (ODEs) refers to the set of conditions under which the solutions of the ODE remain bounded over time. This typically involves analyzing the characteristic equation derived from the ODE and ensuring that its roots have negative real parts.
How do you derive the characteristic equation for a 2nd order ODE?
To derive the characteristic equation for a 2nd order ODE of the form \(a \frac{d^2y}{dt^2} + b \frac{dy}{dt} + cy = 0\), you assume a solution of the form \(y = e^{\lambda t}\). Substituting this into the ODE, you get \(a \lambda^2 e^{\lambda t} + b \lambda e^{\lambda t} + c e^{\lambda t} = 0\). Dividing through by \(e^{\lambda t}\) (which is never zero), you obtain the characteristic equation: \(a \lambda^2 + b \lambda + c = 0\).
What are the roots of the characteristic equation, and how do they affect stability?
The roots of the characteristic equation \(a \lambda^2 + b \lambda + c = 0\) can be found using the quadratic formula: \(\lambda = \frac{-b \pm \sqrt{b^2 - 4ac}}{2a}\). The nature of these roots (real or complex, positive or negative) determines the stability of the system. If both roots have negative real parts, the system is stable. If any root has a positive real part, the system is unstable.
What role do the coefficients play in determining stability?
The coefficients \(a\), \(b\), and \(c\) in the 2nd order ODE directly influence the roots of the characteristic equation. Specifically, the sign and magnitude of \(b\) and \(c\) relative to \(a\) determine whether the roots will have negative or positive real parts. Generally, for stability, you need \(a > 0\), \(b > 0\), and \(c > 0\), but the precise conditions can vary depending on the specific form of the ODE.
Can you provide an example of applying the stability criterion to a specific 2nd order ODE?
Consider the 2nd order ODE: \(\frac{d^2y}{dt^2} + 3 \frac{dy}{dt} + 2y = 0\). The characteristic equation is \(\lambda^2 + 3\lambda +
